for the iso, just a normal dvd will do right?
choose keep nothinghelp help moi prease![]()
The ISO file is around 2plus GB...
So normal sized DVD should work.
Just wondering the key be used on either 32 bit or 64 bit Win 8 OS?
Mine is Win 7 32 Bit OS, bought the key now thinking can use on Win 8 (64 bit)?
Win 8 need so time to get used to. Alot of settings don noe at where find.![]()
Thank for lobang.. Now to look for touch screen monitor
I think there is a tutorial when you first fire-up WIN8
That would be a good learning time...
Otherwise...there is always our best friend - GOOGLE
im currently using vista with ms office 07, if i dl windows 8, will my ms office still be there? or i need to reinstall?
cause my ms office is original one, so i scared if reinstall will use up an additional "key"
why moi nose see the enter promo code part right up till the enter credit card info?
Errr...
So U see the space to throw the promo code or not?
If yes then it is all fine and dandy rite?
If you are asking why it is designed until last part...that one we also dunno wor..have to ask MS.
Pardon for noob question. To make it bootable via DVD, do I just do a simple copy of the contents of c:\ESD into the dvd?
Or the contents of C:\ESD\Windows\*.*
Put it simply, my dvd when open I should see 9 icons or 1 icon?
moi don see it...is it after enter credit card info?
I burn the contents of C:\ESD\Windows\*.* onto DVD but it won't boot from it. I've already set my computer to boot from DVD as priority 1.
Help!
