[NAS] D-Link DNS-320 ShareCenter Pulse
cwm83
Did you check if the script is picking up the correct HDD temp? For my case, need to edit script to pick-up value from RAW_VALUE instead.
I just edit the threshold value. How do you check if the script is picking up the correct HDD temp?
The NAS time always go back to sometime in 2005 whenever i manually power up the NAS. Any way to let it do a sync to NTP server whenever its booted up?
Thanks.
albertlee
Thanks.
Just do a echo `smartctl -d marvell --all /dev/sdX |grep -e ^194 | head -c 40 | tail -c 2` where X refer to either HDD (sda or sdb). Compare the result with that from the NAS webUI.
As for clock issue, most probably the onboard battery is weak which is easy to replace. IIRC, it should be 1.5V, the same type used in digital watch.
cwm83
Another easier way is to check the fan log located at /var/log/fan_tempyymmdd.log
weirdly, i cant find the fan log @ /var/log
Anyway, the script which I used is using this command instead, "smartctl -d marvell --all /dev/sda |grep Temp | head -c 89 | tail -c2" and it reports the same number as the webgui.
albertlee
Which version of the script you using? Mine is v2 and the default HDD temp is taken from VALUE (column 40) which is incorrect in my case, need to take from RAW_VALUE (column 89).
negativzero
Anyone got recommendation of torrent client which supports RSS feeds?
I know uTorrent can't be installed on FFP and Transmission doesn't support RSS. :(
enigma
Lost p2p folder after upgrading latest firmware
:( as above.
After just updating to the latest firmware. I could not find my p2p folder anymore.
Tried rebooting and restarting, also cold restart does not seem to work.
Any way to rescan or restore my p2p folder?
Thanks.
iori_del
Hi guys, i am facing some problem.
There are a lot of files abt more than 100mb having trouble to transfer out from my DN320 to my desktop.
the connection will be down after 1-2 min.
It is all wireless setup. Nothing of this type of problem was surface when the system is new.,
I sincerely seek advise from the user here. thanks alot.
albertlee
:( as above.
Thanks.
P2P folder has been changed to a Shared Folder from firmware 2.02 onward. Just recreate a new Shared Folder if it's not found.
albertlee
Try connecting your computer to the router via wired connection and see if the problem goes away. FYI, this NAS model has poor performance in handling files with small filesize.
You might also want to perform a Smart test and surface test on your HDD using the NAS built-in tool.
goenitz33
Hmmm are green drives not recommended for this NAS?
my Samsung Green drive failed again recently and i had done some readups that Green drives are not recommended for RAIDs.
pharme
Download queue in Transmission
Morning all, can Transmission's download queue number be altered, default is 5?
In the whitelist?
dagobah
Damn! I just realize there's issues transferring files(video) with Teracopy. Is there a way to recover the corrupted files? Any help would be greatly appreciated.
albertlee
Doubt so, this bug is only fixed in firmware 2.03 (aka 2.03b03).
touchme
why issit my desktop can browse into nas volume, while my newly win installed lappy, ask with a dialog box. i key in as admin user and pw...msg says inaccessible...what do i hv to set in the lappy?
cloud77
Anyone using Win 8 Pro here ? After I log in with the IE, it kinda freeze there at the next page. anyone encounter same problem ? Thks
cwchee
I got the IE freeze thing the moment i run the browser
Chrome will also have shockwave flash crash if you run it directly from the desktop unless you run it from the metroUI.
Why?
I dont know
