[SIC] Windows 8 for S$18
tytr
Google is your best friend.
See if it works for U.
I would suggest you to follow the below steps and check if it helps.
a. Press the Windows Key + C
b. On the Charms bar select Settings
c. Select More PC Settings
d. Select General
e. Under General there are Spelling selections
f. Autocorrect misspelled words
g. Highlight misspelled words
By default these are on. If you want to change this, simply slide to the off position.
Keep in mind this is a PC setting, not just an Internet Explorer 10 Preview setting. "
Disable spell check in Internet explorer 10 - Microsoft Community
internet...notch application.
[StAgE]
if you're asking about dota 2.. no issues. :s12:
DotA. Dota 1.
when you run the upgrade assistant, it will do a run down on the programs on w7 for compatibility. my games on steam so far got no compatibility issues.
Ya that's y i asked. Becuz it was 1 out of the 7 apps** that it had compatible problems.
Have anyone tried with Windows 8 and can pak dota 1 through garena?
brianlee_sg
Earlier i mentioned that windows 8 can be a clean installation, but guess i was wrong.
I do a clean installation on my macbook and later realised that although windows 8 can be install and working, it was not activated. I enter the product key and it say this key is only for upgrade and not for clean installation.
tytr
tt32003
If I got a CD key online last night and purchase the box set today, I can use the DVD to install on 2 PC and key in the 2 different CD keys, no need to download and burn on a DVD right ?
Went to Funan and like some bro here said the cashier only charge 79 instead of 89.
But the redemption of the printer was a different story.
At least 200 people were infront of me in the queue to redeem the printer.
Got a number, went walk around , had a dinner, then returned and still got 40 people ahead of me.
If just wait there would have waited for at least 3 hours.
halocast
already got method to fix that.. u can try :s12:
