- Jul 29, 2003
doesn't means sandisk is the best..  i am using silicon power been working for months since i last bought life time warranty too
			around $75 at bizgram for 64gb class 10 sandisk.
That is where i bought the 2 faulty cards...
So any recommendation where can i get other brand 64gb c10 micro sdxc in sg?
Last week bought the sxxxdisk 64gb c10 for my s3. Put in phone then connect to pc.halfway of copying files sudden halt. Then sd card not recognize by phone. Try to format also no use. Put in card reader try to format with pc also failed (exfat, ntfs). Now the card totally cannot use...
I thought card problem. Last night bought another card , try copy file with different pc. Result also same. Now i have 2 unreadable 64gb msd. Anyone experiencing similar situation?
Edit/ omg just saw the other thread that do many problem with these sxxdisk cards. Sianz.... any other brand can intro? Seems only sxxdisk avail at sim lim for 64gb c10.
Go Sim LIm Best Bargain..... they got 2 brands there and is more cheaper the outside shop.....
But only sandisk got 64gb c10. Didnt see other brand with same spec.
I'm doing research for this sdxc card format issues. Seems like many compatibility issue of exfat / window / android. Now trying different method to format the card to fat32. Shall update again.
update:
Some S3 having problem dealing with exfat 64gb cards. File corrupt/missing, card not recognized..etc
Tried to format both card back to fat32 fail. Almost use all method i can use online. Some ppl able format back to fat32 using their old phone. Tried few still cannot. Even go out and bought another sdxc card reader to try. Fail fail fail. Give up. Going back 32gb.
[Q] exFAT file system on microSD cards - xda-developers
so far no luck. looks like your card is really corrupted.
I have tried with Windows 7, ubuntu, mac, almost all the tools on windows. still no luck. sigh!
Let me know when you want to get it back.
I found this article detailing the only format utilities that may solve your problem. EaseUS Partition Master
Format a 64GB MicroSDXC card for Android using your PC – for n00bs | Reinvent The Wheel
Please report back if it solves your problem. I am getting a Note 2 this weekend and would interested if you are successful.
Btw, according to some report, class 6 is preferred. Doesn't make sense to me, but please report. Thanks
i have already tried. it didn't work. Looks like the card is really corrupted. I have also tried with minitool, sd formatter, hp tool usb formatter.
But it could be a bad card. Some are ok with that card, some are not. Good luck buddy. Btw, my computers are running windows 7.
I think yiu have a bad csrd I bought a Sandisk 64gb sd card. It works immeduately once I insert into my note 2
Hi Guys,
I was reading here and at xda that the SDXC cards need to be formated to FAT32 instead of using the phone to format them to exFat.
Please refer to previous poster and my
Wondering if the Note II will have this issue too? Should I reformat mine (awaiting delivery - 64Gb SDHX UHS-1 CLASS 10) to FAT32 or use the Note II to reformat it, or can it be used right out of the box?
Thnx!
Please refer to the previous poster and my reply. The sandisk 64gb class 10 worked "out of box" - meaning no formsting required. I don't think we can make it any clearer.
Note 2 user
