iNO One non-camera smart phone
DigDub
setcpu is pretty stable. 166-250mhz screen off profile.
feitz
我的安卓夹心冰淇淋手机!:)
k3vvie
mine is ok, no reboot so far.
subjective one leh.. more than 10 of us got this phone.. only mine n another got reboot @ 166 / 250. maybe is the voltage thingie not enough for 166/250. But we cannot set the voltage on this phone also... but clock @ min 500 never have reboot issue.
Asphodeli
I am curious; all the phones all running same kernel version?
feitz
it is a carbon fiber look sticker over the white cover. SGD15. Got it done on the spot from a motorbike sticker shop in jalan besar. :)
good worksmanship!
evilguy93
just got my phone today at Y2K! But i encountered some problem with the phone.
When i typed, all the words i typed are underlined which indicates that they are not in the user dictionary, does anyone have the same problem? What can i do about it?
Also, is there a way to off the vibration when touching the three keys at the bottom?
jiraiye
try go keyboard (free) to replace the stock keyboard...
for the vibration, go to settings, audio profile, and then uncheck the "vibrate on touch" option...
evilguy93
Thanks! i managed to off the vibration, but installing the go keyboard doesnt help fixing the empty user dictionary. I typed with the go keyboard but the words are still underlined
xiiaokt
Do they still have stocks in y2k as of just now and just to check we can go down n purchase directly?
teo_simon
maybe you can try disabling this app called user dictionary
