AOC i2757FH IPS LED LCD Anyone?
pa9797
My setup playing PS3 unchartered
pa9797
i will be selling my AOC 27 once my LG EA53 arrive this week. Anyone interested please pm me. delivery included
jyyj87
what's the power consumption like for this monitor? looks pretty nice..
and how many years of warranty does this monitor have?
velato2006
Juz bought this monitor and it looks impressive, but there's one problem..im having blank spaces at the edges of the screen. The display doesnt stretch all the way to the bezel..
FatBomb
Are you using an AMD GPU? If so, you're currently underscanning.
Go to catalyst > my digital flat panels > scaling options > set to 0 > apply
porcu
yup, that can be corrected by adjusting some settings within catalyst.
pker88
those wjo own this monitor
does it have a sound output. input 3.5mm so u
can conect hubstation to it ?
using s ext speaker since the in built speaker is cui
ya I wonder if can use starhub hubatstion remote to control the volume hahaha
velato2006
Nvm, after some googling, i found out that the black spaces are actually the physical internal bezel. Its useless to change the settings. Mine is actually the 23 inches version. Can actually differentiate by turning the display on and off. Quite disappointed , should have look at this monitor closer b4 buying...thought it would be the same as the 27 inches.
velato2006
It does have a 3.5mm output, also comes with the cable as well. i didnt try the monitor speakers coz i already have a high end speaker setup but i would have guess it would be cui.
pker88
oh how is tour connection ?
hubaration hd video via hdmi
and what about sound I know sound it transmit via HDMI to monitor but from the hudsration remote can't up or down rhw volume if I connect from 3.5mm Jack output
what I need is able to control volume too via hubzration remote
any advice ?
velato2006
any advice ?
I think u cant control the volume of the monitor with the remote, coz the remote uses an infrared connection, which the monitor doesnt have, even though u connect it with a 3.5mm jack. But why dont u just control the volume of ur hubstation, which basically do the same thing. Nevertheless, trust me u wouldnt want to listen to ur audio through this speakers, it's like listening from an x-mini.
pker88
oh nope I m hopping to connect a sepeate speaker to the monitor into the 3.5mm output
and use hubztstion remote to control the volume
and hubztstion video use HDMI to monitor HDMI
I try my dell one simile setup but can't control vol via hubststion remote
unless maybe I conect the sound from hubsrstion using old RGB connection cable into a 3.5mm input into the montitor wonder if this sill works
pa9797
Bro, is definitely not a physical internal bezel. I am using Nvidia GTX670 and the resolution can stretch all the way to the egde of the physical bezel. Very nice
