jaywalkra
- Oct 28, 2010
Hi hardware gurus, would like to raise a topic regarding a subject I'm not all too familiar with, and the subject is as stated in the thread title.
Would like to know the best possible positive pressure to (to improve temps whilst reducing dust build-up) airflow configuration for my case. From what I see, it looks as though my CPU cooler is getting little fresh air, and that two of the internal fans may be causing "turbulence" as the air is coming from different directions. OC'd CPU temps max out at 85 deg w/ Prime95, max at 90 deg when running Prime95 & Furmark together.
Here's my current fan config below:
All fans except the 2 Arctics are controlled by NZXT Sentry 2. Speed percentage settings stated above
2 front fans: 2x NZXT FN-120RB @ 80%
1 botton fan: Bitfenix Spectre 120mm @ 60%
1 internal fan: NZXT 140mm @ 100% (came with case)
1 back exhaust fan: 1 NZXT FN-120RB @ 70% (came with case)
2 top exhaust fans: 2x Arctic temp-controlled 120mm
I'm open to any progressive fan upgrade suggestions (ie. buying better fans)
