China Tablets to recommend
BlitzStryker
works well with apv pdf reader and editing doc with a rubberhead stylus.
around 157SGD in total, would be cheaper if you use china air mail.. I pay 25USD for EMS..
If your on simple task, can consider Ainol Legend 7.. so far didn't heard anyone using it yet.. 67USD.. can nego with them through online chat, ask them throw in freebie.
DBS conversion rate is around 1.25+/- if im not wrong.
How to get the 67usd deal? I got this at their website at ard 90usd
Shopping Cart
charlie130
Shopping Cart
PM-ed you the aliexpress link, look at those reviews and comments... saw sg flags on some reviews too.
the 67usd offer is up, a couple of others offers left...those price excludes ems or dhl delivery.
Go to those with no or low negative ratings, but as usual at your own risk....
chee khiaw
Be careful when buying china tablets over net or Sim Lim. Lots of lemons.
Better to go Sim Lim and test the unit you will be buying (not show unit) before payment.
Below are some suggested tests to compare units/models you interested in before payment.
Apps to use to test:
1. AnTuTu benchmark
For overall performance score and compare against known brands/models
Dual/quad core ones costing abt $300 score around 10,000
Lower end models ard $150 score below 4,000
Different units of same model can have 10+% variance in score!
2. Multi touch tester
Use to test touch sensitivity esp at edges of screen
Get app that draws coordinate LINES (x y axis) of the point you touch
As you drag finger over screen, make sure the lines do not JUMP over part of screen which means screen CANNOT sense touches in the area skipped
Since edges are most vulnerable to defects, drag finger from center to edge of screen and make sure no sudden JUMP in the coordinate tracking line drawn by the app as finger approach edge of screen.
Drag finger along edges of screen at 2 or 3 mm from edge and make sure the app detect touch point correctly.
One unit I tested (CH TECH 101A) has almost 1 cm gap on one edge! That means almost 1 cm of touch blind area along one side.
3. G sensor test & graphics
I am looking for an app that can test g sensor
Meantime I run the game Racingmoto to see how good the sensor is
The smoothness of the game graphics also indicate quality of the 'package'
Some tablets have smoother graphic despite scoring 10% lower on AnTuTu
4. Check speakers sound quality
Play music video on youtube etc. and look out for squeaking noises...
Other things to look out for:
1. Wifi
Make sure support n standard. Cheaper models are slower cos they only
Support b and g which are slower than n. N supp longer distance too
Watch tv on HQ if possible. Wifi speed will be obvious
2. Battery capacity and quality
Batteries that charge and discharge quickly are bad news
Check batt level as you run above tests or watch youtube on HQ
Since all of above to look out for are more likely defects and quality issues, mail order can be costly since you cannot do above tests at shop before paying
QUALITY VARIES BY UNIT.
I had to return 4 times to Ainol Shop on 4th floor Sim Lim Square to exchange for the lemons (SANEI, CH TECH) I got from them...
Audiology93
1. AnTuTu benchmark
1. Wifi
for g-sensor can go play store dl apps like g-sensor calibrator
websecom
what about Cube U18GT Elite dual core, 1.6GHZ Rockchip 3066, 1 GiG Ram, 8 GB built in storage, HDMI ports. Alibaba selling 70+ USD only. Ship by DHL all in cost around Singapore S$120 or slightly lesser.
It seem to be the cheapest duo core 1024 by 600 resolution available.
Cube is a well known brand of china.
Anyone owns this one?
is it ok ? stabilty...functions, wifi signal....touch screen responsiveness.... etc etc..
Thanks
Q88 like Ainol Novo 7A just USD$55 including free airmail shipping..now so cheap already :)
between N70HD and momo7, which is a better choice?
websecom
Same here. When I use some China supplied charger to charge my phone or tablets, the response from the screen is like a bit haywire. Sometimes strange graphic appear. BUT when use their original charger, no problem. So I guess the culprit is the type of charger being used.
When use the China supplied charger(some of it) on branded smart phone such as Sony (or even on some other China made devices, the icon on the touch screen like either just shake, no so responsive or even doesn't response at all when touched. Can't open the apps. Even the "turn on" sliding bar refuse to activate.
When verified again with the respective item's original charger, they works fine even use while on charge.
Some times We thought its all 5V what.., can lah. But it isn't the same quality I guess. It does have some adverse effect on the item instantly or in the long term.
If you ignore and just let it carry on charging (because you are not using it during charging, you thought its ok ). You might be risking the device to serious damage. You may wants to take precautionary action if the device is a very valuable to you one.
Cheers.:s22:
websecom
Consider this one :-
Cube U18GT Elite - 7" Tablet, Capacitive, Android 4.0, 8GB Flash, HDMI, Skype, 1024x600 Screen, *Clearance* - Ships Expedited for Free - Now includes Free custom Cube case - $94.99
Do Google search for it. If buying in SL square , may cost almost $200 or more. They will slaughter you. Maybe because their rent is high.
Electronic goods usually the selling price mark up quite a lot. As much as 50% to 200% if you get from the wrong sellers.
Cube U18GT Elite is available from various sellers online at different price range. Some includes freebies, some don't . Other package it up with casing and other accessories.
Alternatively, Ainol Novo fire or Crystal are good ones but cost a bit more.
Just a suggestion only. Follow up more research is all yours.
Good luck.
hi, how do u guys buy the momo7? do they ship direct here?
what are other 7" i can consider within the same price range? must have hdmi out..
websecom
Ya , things moves very fast. Perhaps later got icore 7 ...9 MIC tablets.
There will be no end. But I think for normal uses, dual core one are good enough for the next 2 years or more. Now as said, price falling alot on the single core ones. They become very affordable. Just few months back, they were talking about US$99 tablets being introduced. Breakling the US$100 barrier. Now just few months after, single core with capacitive screens, 512 MB ram and 1 Gig CPU can get below (US)$50 online.
Ainol Novo 7A was hot here then. :)
The last SITEC show, saw a few stores selling single core ones for $100. And one silly store selling single core ones and keep shouting dual core tablets for $99.
But the single core ones, at 512MB ram with 1 Giga Cpu is not so bad actually. Its usable. It all depends on your needs. Some of this are also pretty smooth and not as lagging as someone said.
Quad core is out. Single core which is lagging badly is dumping stock now because even China people dun want them.
C&C2012
Agree that single core (1ghz and 1gb ram) is still usable. I have both single and dual core MIC tablets. No issue to surf basic websites (eg. will have problems loading desktop version of taobao) and watching youtube. Single core will definitely lag when loading and playing games.
shokbakgoc
ya I have a single core china tablet with 512MB ram, use for email, surfing, twitter, tv streaming (cnn, bloomberg, cnbc etc), simple games (sonic, temple run, dragon fly, cut the rope) etc all ok, not much lag.
of course my branded dual core tablet with 1GB ram is smoother and faster esp when using pdf files and for games like asphalt.
waiting for dual core china tablets to drop below S$100 then I will grab one :s13:
touchme
Everything seems opposite me.
My ainol (single) tablet performs smoother than my Acer A500 (dual). I re-bought my missed nook color (single core) last week (black Friday), for $59, Then squeeze balls, when the nook tablet(2 core) offered fit $79, 2 days later.
WhooHoo
Recommendation of tablets
Would be good if you guys could recommend a few value for money tablets with the following specs.
1) Supports 3G (not the external dongle)
2) 7inch, 8inch or 9.7inch (preferble 7' IPS)
3) High res screen 1280 x 800 (1080p video)
4) Shell that is metal material
5) Pricing. The cheaper the better.
Thanks in advance!
Cheers!!! :)
shokbakgoc
is your ainol & acer using the same OS? ICS is faster than Honeycomb. mine 2 tablets are on ICS and have almost identical apps installed, use the same launcher, widgets, wallpaper etc, so the comparison should be reliable.
2 days if haven't ship can cancel order leh.
