The New iPhone 5 Deff Cleave Bumper
suffian
Want to ask everyone here if your draco case starting to oxidize?
I'm using mid night blue and then the aluminium bezel starting to oxidize and becoming dull :(
Mine also starting to oxidise. I used Autosol which is available from ntuc or hardware stores. Works well but becomes super shiny. Avoid e painted parts though.
jaymessofly
Mind posting pics and explaining further on what you mean by oxidise? Interested to get one Draco soon! Wanna find out if there's any problems with it right now! Thanks in advance!:)
bujingyun82
I bought mine at a store on 2nd level of wheelock place. Forgot the store name. It's beside the escalator. All colours available. Selling at S$129. Very satisfied with the case.
tang63
Isnt that epicentre? :s22:
Huh.. I hear all the aluminum oxidizing i scared liao.
netzach
Where to buy that from? Epicentre have anot? I also looking for back protectors! Any to recommend?
I also wanna see. :X Now i scared buy liao.
:s12::s12: Currently using SGP ultra thin air. Does the draco come with sim card slot cut outs?
http://theluckylabs.com/
netzach
thanks for the link. :s12::s12:
You're welcome. Do keep in mind that Teksure side wraps will not fit with a Draco because of its thickness. Had difficultly screwing and aligning back the Draco after applying the teksure side wrap, tore it off and re applied the spectra wrap in the end
aptget
any one knows of any kind of iphone5 dock that works With Deff/Draco ?
borealiszio
tempted lehs. ****hs... :s22::s22::s22:
want a RADDDD one!!! :s12::s12::s12:
bro don't waste money la =p u already have the original one for what you get the oem? and IF you end up liking the red one better, you gonna put ur original blue one aside? thats a waste of money ( but if you are loaded then that's another story ). But you are the first that i saw who gotten a original and going to get a oem one. why not wait or try other oem instead?
netzach
lately no new accessories damn sian. :(:(:(
