Good morning! I know that msi and sharkoon case sold le. Haha. I think my phantom 630 also dun support E-atx. Max support is xl-atx..that one sold away already haha.
Maximus 5 and Phantom 410. The casing doesnt support E-ATX):
Morning![]()
I ish bo bian cuz my budget already very limited so cant get a casing too expensive. If too big also cannot go on my table): Now the mobo is sticking to the case by ONE stand off, i dk if mount the GPU alrdy will the whole thing fall off![]()
Morning![]()
Morning![]()
Wah. Very dangerous leh. Will short circuit the board ltr leh.. Wierd if u get a so exp mobo and a casing that cannot fit. I see ur hoots, de internal hoots so high end, den the case mid range. Haha. Save for a better case that can fit bah.
Case not compatible):nani ? @_@
is u not enough standoff or the case not compatible with yr mobo ? @_@ll
It shouldn't have a problem fitting?
M5F isn't exactly EATX tbh. It's just a slightly bigger ATX board and the 410 should have some space to put it but will cover part of the rubber grommets.
The issue is that the mobo screw holes not aligned with the casing standoffs. Only the bottom one.
Should be can fit. The i/o area got put properly? Try to align properly? If bottom standoffs can fit, should be can fit de. The M5F got how many standoffs holes?
this thread is dead lo
