[Official] iOS6.1 Jailbreak / evasi0n.com / @evad3rs discussion and help [NO PIRACY DISCUSSIONS]
io7891
Hi guys, i JB my iPhone 4S iOS 6.1, after that i cant seems to make itunes and my phone apps tally... I can sync, it completed without any error but what i remove on my com dont remove automatically on my iphone and vice versa.
Please advice?
RyuShinEX
what to do when evasion stuck at stage 2 step 1/3?
on 3gs. :(
did restore and it's 6.12
nvm liao.
zorrus
Moderator
Moderator
so is it recommend to update to 6.1.2 then jailbreak?
i am on 6.1 jailbreak now.
IP5 by the way :)
negativzero
IP5 by the way :)
Why not? You get all the fixes for 6.1.2 and its only a 30min job to get from unjailbroken to fully tweaked out.
toyomi
Got a problem.
Ip5 ios 6.1.2 jb-ed. Unable to view youtube in the apps itself, in fb cannot see, use safari and mctube also cannot see. Got the "play back error" message. My previous jb 6.1.1 no problem de lo.
Any1 face de same problem?
Tks
Mookaa
Got a problem.
Tks
Mine is working perfectly ok.
messi1986
6.1.2 (5 GSM): iPhone5,1_6.1.2_10B146_Restore.ipsw
6.1.2 (5 GSM+CDMA): iPhone5,2_6.1.2_10B146_Restore.ipsw
Which is the correct IPSW? :s11::s11:
Just Me
Should be : 6.1.2 (5 GSM): iPhone5,1_6.1.2_10B146_Restore.ipsw
But no worries, if you try restoring a FW which is not compatible with your phone, itunes will refuse to update.
FSC
Xander13
anyone encounter this issue on cydia ? after i got this errors the external sources under the manage tab is missing.
i tried refreshing but still doesnt work
please kindly advice how to solve.
chengsun
I JB from ios 6.1.2, after that found battery drains much much faster than before JB. I did not installed much things from Cydia, Winterboard, SBSettings, BiteSMS, Activator, about all I can recall. Removed Winterboard and SBSettings, still no better. I am thinking of loading back to 6.1.2. After I jb, I did one backup in iTunes. Now, if I load back 6.1.2, then restore from the backup that I did after jb, will I be able to get back all my data (contacts, apps, sms, settings, ect)?
thanks for all the help here.
