is uevo grey strong enough for hair that is difficult to spike up instead of holding it down as I have rather long hair
For rather long hair, you can still use Uevo Grey but together with hair spray to keep the spikes up.
Just now went to Kobayashi cut hair. Cut by this female hairstylist. She's located at the 5th level branch. She cut really to my liking. This $28 quite well spent. Don't really know what's her name though. Her name seems Vietnamese to me.
Could be Su.
there is only 3 female stylist at that branch, all 3 are different grades
Kobayashi at whwre ?
I am looking for a good hair salon and stylist.
someone permanent in the east
Far East Plaza 2nd and 5th floor
for more info can go to the other recommended salon thread
they are good as a whole, not just certain stylist, however I am not going to overrate them, just giving credit when due and my honest view.
Kobayashi is at Far East Plaza. U can do a quick google search on it.
I know of two good hairstylists in the east. Kayson from Twister, Tampines Mall. He is the salon director. Hairstylists for many top celebrities as well as models. Another one is Gerald from Storm, Century Square. Salon director too. Not as famous as Kayson but his skills isnt mediocre either.
wow thanks for the recommendation but the word "director" kinda means over $50 for a haircut
my budget max is $30.
any recommendation around that range![]()
I think Chinatown is definitely one of those places that you should check out. They carry a lot of hair products. Anyway, i think u are referring to pomade instead of promade. U can check out Murray's pomade if you are interested. Personally, i dun use that. But i heard a thing or two about this though.
Murray's Pomade
Hi, just like to ask, if our hair is already quite long and we mention to the barber, "top layered and trim the sides", where trimming is involved do barbers usually trim the side by shaving a bit or without using any shaver but just trimming with a pair of scissors?
Depends on whether you want to cut slopes or layers.
Think you can just invest slightly a bit more money in going to a neighbourhood salon to get rid of all these doubts that you have in mind. Let the professionals do the job. Just saying.![]()
Need a solution for my hair fall problem.
I try a lot of methods and a lot of products which promise to reduce hair fall.
But so far none of it helps..
anyone tried and tested a method to reduce hair fall?
Hmm.. So basically if our hair is already quite long and we just mention "cut layered", and nothing else, the stylist will know what to do? And normally if cutting Layered, they won't cut slope for the sides?
