Sony Xperia TX - The True T-reX !!
rssd21
Bro did you buy 64gb micro sd already for your TX?
Nope, I reckon 32gb is sufficient since I did not put HD videos.
But I did changed my card once after experiences of Walkman did not read music files in SD card and backup app not working until I removed the card.
Unknownx
Kentang
yes! gotten both done... thanks for the help!
hmm... trying to install my Skyfall theme, but got this error msg when I use Astro to transfer:
libcore.io.errnoexception open failed eacces (permission denied) copy from sd card to phone
& when I use Root Explorer the error msg was Parse error: There was a problem while parsing the package
any advice? thanks!
Unknownx
I used ES File Explorer File Manager when removing SystemUI.odex for statusbar mod. Need to change the root settings to mount writable.
Unknownx
Battery life seems better but I don't know why the "screen" usage is not on the list. Most of the time on wifi, only used 3G for less than 2 hours. Mainly used the phone for FB, whatsapp and listening to music.
rssd21
Yes, battery life seems better.
Mine does show screen on time.
Unknownx
I just checked mine again, now it shows but it only used 2% of the battery for 1 day+. I guess when more than 2 days, it only uses little battery and gone from the list lol. Anyway do you have the option for "WCDMA only"/"GSM only" under mobile network settings? I just realized I only have "WCDMA(preferred)/GSM" option only...
rssd21
Yes, I have 3 options. Its there since 4.0 and no changes.
