[Maylyn's Review] ASUS USB-AC53 Dual-Band Wireless-AC1200 Adapter
maylyn
With the emergence of Draft AC routers since from the 3rd quarter of 2012, ASUS RT-AC66U router have been in the forefront of being the best AC routers worldwide coupled with excellent feature sets rich firmware but AC related adapters are still out of action for quite some time
At last with the announcement and the product launch of ASUS PCE-AC66 and ASUS USB-AC53 locally, one can look forward in fully utilizing their ASUS RT-AC66U routers
So here goes
ASUS AC adapters
ASUS USB-AC53
What's inside
ASUS USB-AC53 Adapter, Extension USB Cradle, ASUS Notebook NetClip, Extension USB Cable, Support CD
Rear
Stylish cradle to provide ease of use in situations of hard to reach USB ports
maylyn
I'm able to cover back my casing top cover with the use of the cradle
Setting up
Setting up is a breeze, just pop in the support CD and launch the utility application, some clicks and that's it
Just launch the ASUS wireless utility application, select your 2.4GHz or 5GHz SSID > key in security key and you are connected
maylyn
Some testing scenarios
2.4GHz
200Mbps SingTel Fiber
Wireless Mode ~ Auto
Channel bandwidth ~ 20/40MHz
Channel ~ 1
WPA2/AES Encryption
Distance ~ 2+m line of sight
Signal Strength ~ 20+ -dbm
Adapter Status
SpeedTest
SingTel
SGIX
Viewqwest
Results have shown the ASUS USB-AC53 is saturating the 2.4GHz N has to offer. Nothing special, it's just 2.4GHz
maylyn
5GHz ~ AC Mode
300Mbps Viewqwest Fiber
Wireless Mode ~ N only
Channel bandwidth ~ 80MHz
Channel ~ 149
WPA2/AES Encryption
Adapter Status
SpeedTest
SingTel
SGIX
Viewqwest
Results have shown the ASUS USB-AC53 is more than capable in delivering high speeds in 5GHz AC mode
zuoom
Are there any 2.4 n 5 simultaneous USB adaptors out in thr market?
Only see one or the other.
toshm200
hi maylyn,
My data rate always start at 175 Mbps when i switched on my laptop using this USB-AC53. Always need t go to RT-AC66U GUI to click "Apply" on Wireless - General page to revert back to my max data link at 585 Mbps. Do you face the same issue ?
Thanks
ASUS@SG
Suspended
We are giving away Free Games "FARCRY3" and you could stand a chance to win the games. Follow the below step
1st: Join ASUS Club
2nd: Click Like on ASUS Club at first post
3rd: Click Like on ASUS SG Facebook: http://www.facebook.com/asus.sg?ref=hl
- Winner will be notified via PM within 1 week after the contest.
- Contest period: 14-April 2013 to 22-April 2013.
Join ASUS Club Here: ASUS Club - Part 2 - www.hardwarezone.com.sg
ASUS@SG
Suspended
hi maylyn,
Thanks
Dear toshm200,
Connection link - is "up to 867Mbps"
Are you able to utilize 575mbps speed?
toshm200
Hi Asus,
My issue here is whenever I on my laptop, the USB-AC53 UI indicated I'm only have speed link of 175 Mbps (5 GHz). I've to go into RT-AC66U GUI page to click "Apply" to so call "re-activate" the speed link back to 585 Mbps.
Theoritically I'm not able to utilized 585 Mbps or even upto 867 Mbps but this but this is kind of annoying as I always need to go into RT-AC66U GUI page to click "Apply" :s13:
Any solution ?
Dear toshm200,
ASUS@SG
Suspended
Hi Asus,
Any solution ?
Dear toshm200,
Shut down your pc and switch off your router for 5mins.
power up your router and pc. check the connection speed?
i'm using USB-Ac53 on my office laptop connection speed at 867mbps inside my room.
toshm200
Hi Asus,
I'd monitored these since afternoon and based on ur recommendation I'm able to get 586 Mbps on speed link. I'd off my laptop from 1pm til 10pm and just switch on, the speed link goes back to 175 Mbps. Can you advice again ?
Thanks.
Dear toshm200,
ASUS@SG
Suspended
Hi Asus,
Thanks.
I believe your router using the 5ghz settings that i recommended you right?
can you show us your connection signal?
toshm200
yes... using ur recom 5 Ghz setting. The connection signal is on 5 full bars (sorry... still can insert print screen)
