Galaxy S4 :4.9inch smartphone
snowdrift22
can i just ask ah. is it possible to use the iphone iflexi lite plan with the samsung s4?
Also, can i extend my iphone plan to buy the s4?
Anyone in the know? :) Many thanks.
elysdeon55
Hmmm my time slot is the last time slot for Sunday Starhub 8-9pm... so imagine if everyone infront all tio jam then my will be sibei jam liao !!!! maybe i should go at like 9pm lol.
FlushX
Your data plan can be used across all phones, except for probably the older BlackBerry Models. By doing a recontract, your plan will be changed to the new Flexi Lite with 2GB of monthly data. Excess usage is charged $10.70/gb since you will be on a 4G Plan.
es0teric
Just tried S4. Basically the air gesture is awesome. You can don't need to touch the screen to view other photos. However, I tried it's only workable with photos but for others it can't (scroll from down to top or top to down)
Hello_Kitty
Yah.. unless samsung found a better way then sony. Waterproof battery, water proof memory card..
Actually, all the Japanese phones I used have removable battery and SD card and still waterproof like Panasonic, Sharp, NEC, Fujitsu, etc.
swsw88
Today I finally touch the s4 at MBS. The phone is really very light but the apps abit lag maybe need to wait for the next update
Hello_Kitty
Went shopping with my friend he wanna get S4 on sat. So I accompanied him to go test out the phone. Surprisingly after a few minutes of testing this appear and hang for quite awhile many customers waited to do testing or overheard came over to take photo of this. It quite disappointing. My friend decided to give it a miss.
i find S3 and S4 difference not a great leap.
So i am waiting for S4 waterproof to replace my Xperia Z
hope that S4 speed will not laggy
Hello_Kitty
if you find S4 to be plasticky and laggy so do not buy. Spend your money on something that you like. This is basic common sense. Move on to the next forum
what's wrong with potential buyers comparing phones? we find out the cons and the pros and see what 's the min we can tolerate.
if we just keep on praising the phones , it is like not comparing fairly right?
chongbh
I tried on the Multi Window feature on S4 and the bar for the multi window can be quite irritating at times though it can be turn on or off in the menu setting.
But the lack of flexibility to add more apps from the PlayStore is really a disappointment cos it only comes with the default preset apps compared to the Small Apps in the Xperia Z which you can install other apps developed by other developers like camera function etc, this is so much useful.
Happen to see the review in the Today Newspaper so just post here for you all to refer.
kelvinti
The Air Gesture thingy will make your hand and fingers very tired if you keep hovering all the time lol.
