Anyone.encounter your RT-N66U will auto power off?
Don't know when will it happen. Once happen, I need to unplug the power cable behind the router and plug it in again.
Dont make sense to me, ur n66u internet speed will be limit by your homeplug
Just replace the engenious with just n66u![]()
Whats the market price for this router? I might be getting the M1 200mbps @ 39 per mnth.. shud I buy it frm M1 or wait for IT SHOW?
I understanding the 2nd router will be use as a repeater but can printer n usb storage work if connect to 2nd router(n66u)?
For new subscriber, can but this at SGD209 (I cant remember this clearly, but around this price) at M1 shop
Or, Amazon now ship this directly to SG, USD149.99, add in shipping USD13.66, total is only USD163.65.
U asking me put my printer from study room to the living room huh?
Don't forget there is no warranty if you ship from amazon!
Can amazon sell customers things without providing warranty? I thought, the Cons is only that you need to send it back to Amazon, that's all?
Anyway, I saw the option of adding 2 years warranty, only need to top up USD10+
depend on what your priority.
cause if internet speed isnt your 1st priority, then your setup is fine.
Why i say that, when your bandwidth from your engenius router go through the homeplug, it can be only around 30-40Mbps (might be more but on average that is the speed). what your n66u router receive will be only 30-40Mbps.
So if your device that are connected to the n66u wireless or wired, your internet speed will only be around 30-40mbps. But those devices that are connected to n66u transferring file, u still can achieve high speed as it within the router.
So if u got PC connected to engenius via lan transferring file to PC connect to n66u via lan. bottom line will be limited by home plug speed although both are gigabit router.
k.. currently i can get more then 100mbps for my m1 100mbps plan from my homeplug... i test file transfer between 2 pc using homplug is about 15mb/s so should be ok right
? i didnt know if items bought from amazon can send back to amazon then they will rma to the company where the product is bought from
my new HP Elitebook company laptop cannot connect to the 5GHz channel. It will work with the 2,4GHz channel only.
