The Intel LGA1150 Haswell Owners Thread & Survey (H.O.T.S)
Are you buying Haswell? If possible, explain your choice in a post
  • Total voters
    275
MacClipper
Without AVX, load temps are significantly lower - compare HyperPi vs LinX DTS temps.
HyperPi 32M
HyperPi_4670K44GHz_1866C9_AdaptiveVcore_8m3sCopy_zps734c5a9c.png~original
HyperPi 32M - 74C
LinX Stock Run - 87C
Difference = 13C
So the 10-15C gap for AVX instructions still holds true, ever since the days of Sandy Bridge. :)
PS: took more effort/volts but managed to run core:uncore at 1:1, this sweetspot o'c seems holding quite solid so far
MacClipper
Riptbot264
Ripbot264_4670K44GHz_1866C9_AdaptiveVcore_OKCopy_zps58920691.png~original
Max DTS load temps noted, for comparison
Ripbot264 - 78C
xvid4PSP - 76C (posted earlier)
Note - both Ripbot264 and xvid4PSP had the transient Vcore swing (to 1.272V) which the Asus guide attributes (?solely) to AVX instructions being used somewhere. ime, so far LinX AVX produces the highest DTS load temps.
aCuria
Yup, it seems that if a CPU is a K series then TSX is not present. However two non-K CPUs don't have TSX as well: The i5-4330 and i5-4330S. I got my information primarily from this table here:
Core i7-4770K: Haswell's Performance, Previewed : Core i7-4770K Gets Previewed
Unfortunately it's a piece of information that not many sites cover.
I think Intel is causing quite a bit of confusion with their products like this, as what SKU has TSX or not is quite arbitrary.
From that page it looks like as long as it has a "-70" post fix and no k it has TSX. I cant understand why they want to disable this feature though, TSX is something you want to have widespread adoption of, otherwise its probably better to stick to a software implementation of TSX... which is what people are doing now anyway
MacClipper
Uncore Frequency
In Haswell, there exists the option to unlink the cache (so called uncore) frequency from the CPU core frequency so looks like got to include the monitoring info in hwinfo from now onwards.
UncoreCopy_zpsd7fb8499.png~original
Elijahonli
for anyone picking up a haswell who are interested in OCing...
maybe this will help?
MacClipper
Uncore-rigible...!
... or die die must at least get 4.5!
★ Asrock Z87 Extreme6 | i5-4670K Retail | 8GB KVR1866 | Enermax 240ELC | HIS HD7850 IceQ X Turbo | TT Smart 630W ★
Ambient non-aircon temps
P95 Blend AVX
P95Blend_4670K45GHz_38_1866C9_OK_14minsCopy_zpse715c0a8.png~original
LinX AVX Stock Run
10xLinX_4670K45GHz_38_1866C9_119GFlopsCopy_zpsf22d6d59.png~original
Cinebench
Cinebench_4670K45GHz_38_1866C9_767ptsCopy_zpsc0680629.png~original
WinRAR
WinRAR_4670K45GHz_38_1866C9_5782Copy_zps56b4c61d.png~original
7Zip
7Zip_4670K45GHz_38_1866C9_21112Copy_zps342056ed.png~original
HyperPi 32M
HyperPi_4670K45GHz_38_1866C9_7m57sCopy_zps6b0b851a.png~original
SettingsComparedCopy_zps41c8011d.png~original
After consulting the Asus OCgasmic Kamasutra and other more experienced Haswellers to attain enlightenment where some categorically states "Core Frequency is still King!"... OK, back to testing and so prepare to Unsync That Uncore, tada!
As can be seen, this is still not the end of testing cos now trying to find a sweetspot for that uncore next. :)
MacClipper
Can i ask whats the max you can overclock while keeping max temperature below 70 degree?
Wrong platform if you want to o'c and stay below 70C max load, unfortunately.
My AMD Richland sharing thread should be incoming real soon though. =:p
xkiller213
you all not concerned with the usb3 bug meh? or is coz your desktop would never go into standby mode?
MacClipper
For Shrek since you asked for it...
Wakao This Uncore leh!
... more uncore settings vs performance, testing Core@4.5_Uncore@4.2GHz
LinX AVX Stock Run
10xLinX_4670K45GHz_42_1866C9_118GFlopsCopy_zps79a6d9e5.png~original
Cinebench
Cinebench_4670K45GHz_42_1866C9_770ptsCopy_zpse560628c.png~original
WinRAR
- kindly excuse the momentarily drop in core speed during screen capture
WinRAR_4670K45GHz_42_1866C9_5789Copy_zps3a9d0a68.png~original
7Zip
7Zip_4670K45GHz_42_1866C9_20596Copy_zps350af899.png~original
HyperPi 32M
HyperPi_4670K45GHz_42_1866C9_8m14sCopy_zps3745e7e9.png~original
SettingsComparedCopy_zpsc045afd9.png~original
Seems kind of weird findings so far, hope others can try out uncore scaling and post their feedback too. Looks like Core Frequency is really still king and the stock uncore speed is already fast enough to feed the core at 4.5GHz. :)
duffie
We're in Singapore! If Revision 2 comes out you simply build a new rig for Internet surfing in August. :)
