Dr_ARCHer
- Jul 27, 2001
Bro, thats a firewall not router.![]()
Errr... they are Layer 3 devices, right?
Tik Guru @ Blue Forum suggested RB1200 to load balance and it hits 1+ Gbps NAT throughput
using RB1100AH now for my ST200 and VQ300..Tik Guru @ Blue Forum suggested RB1200 to load balance and it hits 1+ Gbps NAT throughput
LoL.... $740![]()
But tested and proven - when i was on course at this location i personally tried it FortiGate-80C @ $1200![]()
FortiGate-100D @ $3000
FortiGate-110C @ $2600
yeap bout there...I am intending to get a Zywall 50 or 70. I used to have a Zywall 5 and 10, and they are absolutely solid routers.
PS. I'm waiting for my 2nd line from VQ, so we can exchange notes on how to do the setup.
My 1 cent of input.
Peplink Balance - Compare Specs
But I think u won't want to pay the price juz for home usage.
why dont bother with 80c? spec seems higher then 110c80C? Don't bother...
Worked with the 110C & the newest 100D - after adding UTM/AV etc. maintenance - averages out close to $3K - really love these over sonicwall - anytime.
Can try looking at Sonicwall - Have got a TZ 205 now with me for testing - pretty decent - tested OK on a 200Mbps Singtel line...
Should suffice your requirements.
I'm using 110c for office, very good and fast, and cheap too (compare to cisco + symantec utm + aruba)
But some people seems to suggest that the Zywall is better than the Peplink.
He's using for 300Mbps
Ports are 100 base only...
I've got a couple of sites on 110C / 100A / 300 series... love all of them.
Can't say much for their firmware support.
Currently pissed to the max as they had me upgrade 1 of my sites - which - not sure why - caused the forticlient license key to go missing and they're refusing to help me recover it.
