Aztech DSL7000GRV router from Singtel
tanyj82
QOS on this router
Just got this router today and i cant find QOS function on this device.
Anyone know how to flash 3rd party firmware ?
guyz92
Inside the Admin page
192.168.1.254/singtel
password is provided on previous post.
micarforum
is this Aztech 7000 router able to do bridged mode, so that I can connect my own router to do DHCP and wifi?
madhardy4
The speed for using wireless seems to be only limited to 50-60Mbps only but when I'm on wired connection, it goes up to 150++Mbps. What other routers can I substitute with the Aztech to achieve 150Mbps on wireless? Will the setup process of the new router be difficult?
OR is there a way to change the settings in the admin page to increase the wireless performance? BTW my PC is getting full bars consistently.
micarforum
if you can set the Aztech router to be on bridge mode, then you can get a good router for wifi.
darrentsh
Hi guys,
How to configure portforwarding for this router?
Tried key in data at port forwarding tab but not successful leh.
Thx for advice in advance.
i tried today, it works! u solved yrs already
Kvicez
Hi,
I was using the 2Wire 5012NV for 2 years and upgraded my plan. They did not offer me an equipment upgrade or replacement.
I requested for an equipment upgrade because I plan to wire up my home. The 2Wire 5012NV has only 1 gigabit port.
SingTel replaced my 2Wire with this Aztech router today.
Cheers!
guyz92
Hi,
I requested for an equipment upgrade because I plan to wired up my home. The 2Wire 5012NV has only 1 gigabit port.
Cheers!
I got my new router for FREE.
recontact should be giving new router.
You should check with Singtel see if they are suppose to give you new 1 (not trade in) or not.
iantao99
Still cannot leh.
I set my server to static IP 192.168.1.128, Port 1234
At port forwarding and triggering, open port 1234 ad IP .128.
When on home network, I key in URL http://192.168.1.128:1234, I can access my server.
But when i tried remote access via my router WAN IP xxx.xxx.xxx.xxx:1234, cannot access leh.
Any bros can advise what i'm missed?
leodrio
Still cannot leh.
When on home network, I key in URL , I can access my server.
It doesnt work when using home network to access WAN IP. Try using your phone or another external network.
Justintown
any current aztech router users doing bridge mode (with another router as DCHP+wifi)?
, I did connect my time capsule to the aztech n my time capsule is giving better wifi speed
I m trying to connect direct to singtel ont n bypass the aztech. Frankly I dun need aztech other then bridging to the ont
Any experience to share ?
Twk
support nat reflection
does this router support nat reflection?
i'm able to configure ddns on it. I'm able to access my nas from external network, but i am not able to access my nas via ddns on my lan/wifi network.
