Aztech DSL7000GRV router from Singtel
micarforum
I managed to get the Aztech to be on bridge mode, but miotv is not working when i plug into the aztech, anyone managed to get it to work?
iantao99
does this router support nat reflection?
i'm able to configure ddns on it. I'm able to access my nas from external network, but i am not able to access my nas via ddns on my lan/wifi network.
Same here. Managed to setup DDNS, but can only access via external network.
With local network, got error cannot find server...
Any bros can advise?
micarforum
Mine's working. Try other ports on the Aztech?
what r the settings u changed on the aztech? for me, i disable dhcp & wifi, den change connection mode to bridging. that's all. then i plug lan1 from aztech to my wifi router, internet works for all my devices. plug miotv into port 2 of aztech, doesn't work :(
Pathfinder
I only change connection mode to bridging.
micarforum
oh. so Aztech is the one assigning the DHCP/routing? would the performance of the wired devices be affected, since i got several devices connected to my own router?
micarforum
u sure that's the only thing u did after the singtel person installed the Aztech? Coz I tried to reset my modem and just set to bridging, and off the DHCP on my own router, doesn't work.
According to the Aztech technical hotline, we just set to bridging AND disable DHCP on the Aztech, in order for us to use our own router, and MioTV will not be able to work.
evewbb
hi guys, i have the Aztech 7000 modem provided by SingTel - previously was on Pace.. the weird thing is when i transferred the cables from my Pace to Aztech, the broadband light is Red, all other lights are fine - and I can't use my internet. When I used back the Pace - surprisingly the broadband light is green - is there any settings i missed out? I thought Aztech was also a plug & play..
TIA
guyz92
TIA
try reboot your ONT and the router together.
Twinsen
Trial starting next week. They getting volunteers through Singtel Advisors community. Hope I get selected
ideatalk
i am invited but i skipped bcoz lechel must personally collect at fix time and date and return. initially i tot can keep the router after the test
micarforum
what's there to trial? not as if 5ghz band is on beta or what... they should seriously just give out the Asus routers, I will even pay for it, rather than the current Aztech or Pace crap...
Twinsen
I prefer the RWS invite they are giving out at the end of it. Don't need another dual band router.
guyz92
Still having issues connecting to xbox live via wireless...
http://192.168.1.254/aztech_lancfg2.html
try enable UPnP support in this link.
By default it is disabled.
5GHz Support on Aztech DSL7000GRV(S) is supported but Disabled by default.
You have to hack the router to allow the 5GHz configuration.
All you have to do is to use opera or google chrome to edit the html code LIVE.
And send the configuration mode back to router to allow it to work on 5GHz mode
ES
What is the right setting to use for port forwarding for my Dlink IP camera?
Use Interface: INTERNET/Eth0.1 or quickstart/ppp0?
Do we need port triggering as well?
Also encountered funny connection issue viewing my ip camera.
Wi-Fi - 192.168.1.XXX:8080 - OK
Wi-Fi - WAN Address - Not OK
4G/LTE - WAN Address - OK
Many thanks in advance!
Twinsen
Interesting. Can give some instruction on how to do this? Thanks
