Nitrogen Gas Pump
WhiteWright
Hi,
Can anyone recommend me a place where I can pump nitrogen gas for my tyres? Preferably around Ang Mo Kio area.
If so, do you have experience in doing so with them and how much do they charge?
Thanks!
q w e r t ii
why do u specifically need pure nitrogen gas?
air itself is made up of 78% nitrogen, i am pretty sure pure nitrogen would not make a big difference
just go any petrol kiosk and pump air, its free too :o
AL5509
I heard it helps but troublesome to maintain and to have to pay as mentioned.
However, having to use nitrogen gas for your wheel may just help.
Why said so?
Am no guru but becausedI googled.
As follow (please do not quote me wor);
Q: Is there any advantage to using nitrogen instead of compressed air in tires? Will I notice improved fuel economy or a smoother ride? Will my tires last longer?
A: Sort of. From the top: Air is 78 percent nitrogen, just under 21 percent oxygen, and the rest is water vapor, CO2 and small concentrations of noble gases such as neon and argon. We can ignore the other gases.
There are several compelling reasons to use pure nitrogen in tires.
First is that nitrogen is less likely to migrate through tire rubber than is oxygen, which means that your tire pressures will remain more stable over the long term. Racers figured out pretty quickly that tires filled with nitrogen rather than air also exhibit less pressure change with temperature swings. That means more consistent inflation pressures during a race as the tires heat up. And when you're tweaking a race car's handling with half-psi changes, that's important.
Passenger cars can also benefit from the more stable pressures. But there's more: Humidity (water) is a Bad Thing to have inside a tire. Water, present as a vapor or even as a liquid in a tire, causes more of a pressure change with temperature swings than dry air does. It also promotes corrosion of the steel or aluminum rim.
If I ever need to top off a tire when I'm out on the road, I'll always briefly depress the tire chuck's valve with my thumbnail and vent some air. If my thumb gets wet, there's water in the line. Some gas stations don't do a very good job of keeping the humidity out of their air system. I don't even like to use a water-based tire-mounting lubricant unless I can let the tire bake in the sun for a couple of hours before I air it up and seat the bead. I've dismounted tires (not mine) that had several quarts of water inside—probably from a compressed-air hose that collected water and was never purged properly.
How is water relevant to a nitrogen discussion? Any system that delivers pure nitrogen is also going to deliver dry nitrogen. Filling tires with nitrogen involves filling and purging several times in succession, serially diluting the concentration of oxygen in the tire. This will also remove any water.
It's certainly simple, although time-consuming, for a tire technician to fill and bleed tires. But most shops use a machine that not only generates almost pure nitrogen by straining the oxygen out of shop-compressed air, but will also automatically go through several purge cycles unattended. Some shops have been charging as much as $30 per tire for this service. I think that's too much. If you're buying a new tire, it should be far less. Still, the nitrogen generator, filling system and technician's time aren't free—the dealer is entitled to some return for that.
So, to answer your specific questions: With nitrogen, your tire pressures will remain more constant, saving you a small amount in fuel and tire-maintenance costs. There will be less moisture inside your tires, meaning less corrosion on your wheels. You will not be able to feel any difference in the ride or handling or braking, unless your tire pressures were seriously out of spec and changing to nitrogen brought them back to the proper numbers.
eurofunk
I always go for the free nitrogen provided by the tire shop as they provide lifetime balancing rotation and nitrogen
winfong
Try... Helium ^^.....
and... maybe...
The forever Alone GAS.....
HYDROGEN... ^^ Boom ....
HeadQuarters
and... maybe...
Tiagong palm helium liao the car can take off vertically like a helicopter :s13:
U'll no longer be caught in any jam :o
Genesisz
Why said so?
Thanks for sharing.
I still pump normal air at petrol kiosk when I checked my tires weekly or regularly.
Genesisz
so nitrogen offers no significant benefits?
My previous sets of tires are on nitrogen.
My current ones are on normal air.
I do not see any difference as I do pay attention and care for my car, including my tires (checking them regularly and pump them).
bolts
Hi,
Thanks!
soh brothers is at any more kio. try that one.
no one really answered the question.
Providence
Most of my buddies used nitrogen to pump their car tires because their cars have been modified to become track cars. :D
I just pump normal air from any petrol kiosk. Anyway, my car is not modified. Just a family-oriented vehicle.
socketer
I check the tyre pressure once a mth only, and very little dip in pressure... I can live with this, no need nitrogen
