China Tablets to recommend
blue00
my frd bot aosen tablet, he exp battery drain when google play store is turn on.
Once i disable his google play store, battery drain stop.
anyone heard of this issue?
Edz_Sg
Anyone care to advice? As I got my Vido Mini One, plug-in USB to computer windows 8 64bits.. detected, downloaded the driver from official website. go device manager to install driver, but it say not working.... any help?
FIREBOWS
Have you enabled the following in your Mini one yet?
On your Mini One go to Settings->Develop Option and enable USB Debugging
Edz_Sg
Yes, as computer device manager already detected mini one, but saying error no driver found. download from official website also cannot use =.="
FIREBOWS
I just flashed my Mini One to 4.2.2 this afternoon.
I have similar problem like you with the usb driver attached in YuanDao folder too, so i google ADM USB driver for rockchip rk3188 and installed and it works.
FIREBOWS
Do I need to like press and hold this button and that button?
me still in 4.1.1
I did not press those button.
After install the ADM USB driver, run the RKBatchTool.
The RKBatchTool is inside the sub folder, i keep getting error when running from there. So i create a new folder in desktop and copy RKBatchTool, config, UID, Log, Language over, and run from there instead and finally it works.
After selecting the image file, the tablets will be indicated as "Pink" colour, press the "switch" button below and it will turns Green and you are ready to flash it.
Shadow79
Hi guys, need some recommendations for a 9.7" MIC tablet with retinal screen. Main usage would be PDF reading and occasionally video playback. One of my concern would be the speakers. Need to be relatively loud. Having own several MIC tablets before, their speakers is a hit or miss. Currently looking at the Onda V970. Their firmware seems to be prompt. Another other good recommendation?
Edz_Sg
Having difficulty on windows 8 64bits... now trying installing windows xp platform and try see can work or not =.=
Windows XP working fine after doing all the windows updates =.="
thinking should I upgrade to 4.2.2, as heard this version is very buggy
Teo Ming Ern
Suggest not to lar... there's nothing wrong with the current firmware... don't fix what ain't broken.
Also the Batch Tool should work on Win 7. The Tool is not updated for Win 8, so I expected that there may be compatibility issues, especially driver side cos Win 8 is more rigorous in inspecting unknown drivers.
Teo Ming Ern
There are few tablets with very powerful speakers... I know of none for 9.7 inch. But for 10.1 inch, the Ainol Hero, either dual or quad core has incredibly loud speakers. Little or no distortion Evey at max volume. You may want to consider it. Not quite retina but full HD on 10.1 inch screen.
ericmaxman
Full HD = 1080p
HD = 720p
The Ainol hero has a 1280x800 display..
I think more of accidentally ejecting the card when the edge is pressed against something.
Which leads to data corruption...... :s22:
Teo Ming Ern
Actually I have no idea where this press power button and volume - key thing came from... it's all over the internet...but it's just nonsense... cos the way to use the RKBatch Tool is a lot more simple than what it has been made out to be... the only glitch is that the installation of the tablet drivers are not straightforward. This is because none of the Chinese companies have written specific drivers for their tablets. The reason being that underneath the skins applied for their interfaces, all the tablets are the same, there is no secret sauce at the hardware level unlike the international brands. And for this reason, many of the Chinese manufacturers also don't host the ADM USB drivers on their website. You have to go to the Rockchip website to get it and install it. And because it's a barebones driver (i.e. no automatic installer), it doesn't even automatically install the tablet when you plug it in. You often have to go to Devices on Win 7 and manually locate the drivers and tell Windows to install it.
After which, the use of the RKBatch Tool becomes straightforward... up till now I have not yet seen a straightforward written procedure for using this utility...
Teo Ming Ern
Full HD = 1080p
HD = 720p
I think the quad core version is full HD right? The dual core is confirmed 720p only...
Actually ejecting the SD card without unmounting doesn't corrupt the card... I also don't know why so many people say it would... as long as the card is not being read halfway, you should be able to simply take it out... it's hot-swappable...
Force89
Just purchased the Chuwi V88s. Should be better than the original V88 other than the difference in ram. :D
Teo Ming Ern
Walked around SLS quite often these days... getting stuff repaired...
Some new tablets that I observe... this shop is opposite the bubble lifts on the 4th floor. Can't remember the name but it's beside the Orient Electronics which specialises in selling mobile phone and tablet cases... they carry a few interesting tablets...
1) HKC 8-inch tablet with telephony. You can make calls using this tablet. Runs on JB. IPS screen. Single SIM though.
2) Viewsonic 7-inch with telephony. Dual SIM, both are on standby simultaneously. Runs on ICS. But lousy screen, TFT LCD, screen goes almost black at around 160 degrees from the normal.
3) Viewsonic 10.1 inch with built-in 3G. Metal casing. Pretty good wifi reception. Runs on JB. Very smooth. Dual core. Didn't have opportunity to check the rest cos the battery ran out and I was in a hurry to leave. Note that the tablet was pretty heavy.
This shop says they are the distributor Viewsonic tablets in Singapore and they have a local repair centre. So no need to ship back to China. Sounds good.
And then the stall next to the one above. If you face this stall I talked above, on its left there is another stall selling tablets... here's what is interesting...
1) They carry the ICOO Fatty 2. Price is pretty good... less than $250.
2) They also carry the Chuwi V88. Same price.
But not sure how reliable they are lar... probably one of the satellites stalls of the two major players in SLS.
On another note, CH2 Technology now has an in-house technical service centre at the back of SLS... so if your tablet got problem, they will attempt to repair it first... so the turnover time is very good. I sent a Cube U30GT-H for reflashing as it got stuck at the boot screen. They did it overnight. Sent in on Sat afternoon, Sat evening (around 8pm), they called to say it was done. Went back on Sun, and the tablet has been working beautifully. I complained about the 32GB mSD cards not working... now it seems to be working perfectly... so it might have been a case of a poor flash the first time around. The first time around, the tablet came with a Win 8 skin which I didn't like and so got it flashed to the regular MIC tablet launcher (done by the techs at the service centre, not by me). Which then proceeded to give me lots of problems with the mSD card where the whole tablet would hang... and so it finally crashed the tablet such that it stopped booting at the Cube splash screen... thankfully the tablet could be salvaged...
For those on a budget, but want an international brand... PC Dreams is selling the ASUS Transformer tablets for a steal. All factory refurbished. 1st Gen at $199 but it is only on HC. Can't be flashed to JB. 2nd Gen, Prime at $350, can be flashed to JB. Comes with the dock as well. Quite a good buy. Only caveat is that the Prime is made of spun aluminum and there was issue with the GPS and wifi signal strength in the past. The TF600 and another later model is also sold but the price was not advertised... I think the best bang for buck is the Prime. Less than half price but almost new. And comes with dock. I don't think the tablets are on JB so you got to flash it yourself. The firmware must be sideloaded I think... it's not OTA. I think it's too large to do so safely.
Ok, end of updates... hope it's been useful...
ericmaxman
Nope, quad core also same display.
I had bad experience with it. :( Card + data gone.
