M1 FIBRE BROADBAND DISCUSSION / NETWORKING SETUP / INFO / PROMO
zeroisland
Do I have to do:
l--LAN Port3-->(WAN port)-- HG256--(RJ11 port) --> Phone (for fixed voice)
I'm using 100M and I've re-contracted my plan and upgraded to 200M this afternoon. Is the instruction here applicable to me? Why do I need to connect HG256 to router to get the fixed voice? Can I just connect it to the black ONT?
The M1 CSO told me now the phone line can be directly connected to ONT, and HG256 can be returned to M1. I forgot to ask him when I can do the switch, but I remember he told me by tonight the speed will be 200M. However, I reconnected everything just now but it doesn't work. It seems the new 200M fiber is still not up. I think I should wait for a while.
ngbc
Do I have to do:
M1 normally do the upgrade after midnight.
In the mean time, for those who are on black/white ONT + RG previously and WANTED to setup the N56 while waiting for the upgrade, steps at post #7002 are applicable in order to get internet via N56's LAN port 1,2&4 and voice via RG at port3 of N56.
For those using Black ONT, once you're on the above setup, and suddenly cannot access internet, you know that M1 has upgraded your plan. You should now set back the Select ISP Profile to "None" and reboot N56 while you plugin the phone direct to black ONT's "TEL1" port. After you confirmed LAN port 1,2,3,4+Wifi can access internet and fixed voice is working, you can return the M1 RG.
mata_hippo
i am on 100mbps but signed up for the 200mbps
i still can access internet with my linksys e1200 but when i use n56u, i cannot do anything...
i alrdy tried switching off both n56u n black ont... then wait for awhile on black ont on n56u...
im stuck at the router configuration... cant auto detect...
ngbc
Then post #7002 don't apply to you, and N56 should be set with default settings. Make sure Select ISP Profile is set to "None" for your case.
Black ONT (Lan port #1)-> (WAN)N56 (any Lan port)-> PC
mata_hippo
doesnt work... still got the same message...
fuzzybear
i dun think i have to try that ba...
i have no problem with my old/current router, linksys e1200...
i just renew my m1 fibre too last nite saturdat arond 8 to 9 pm
to 200mb
but not upgraded the speed but i stil can access on my old router
but the CSO say it will be boosted today which is now but not booosed i guess i need t wait
i am on black ONT on day 1
i have also did the ONT and router power down and power up
for your case wise did u set auto DHCP?
see if works?
mata_hippo
to 200mb
see if works?
yea everything auto :s22:
urs working?
ShivaDagger
Hey guys, kinda need help badly here. I actually need to connect my new fibre 200mbps black modem to my previous Huawei white rg due to incompatibility issue of the new linksys ea2700 router with my wii.
When I connect the Huawei router to black modem, it does not get Internet connection. Also, is anyone getting issues with wii and linksys ea2700? I really have tried hundreds of ways to get it to work but no avail.
Anyway the wii error code I got is 52130, which means there's connection to router but no Internet access. I have some IT background knowledge so I have done some of the mandatory checks.
Hope someone has an answer here, thanks!
fuzzybear
maybe u try to explain from the start
why go back white ONt with the RG?
what black modem?
or u not sure take a pic of your equipment
what m1 provide now is
either white or black ont
and RG which is for those under old white ONT
then from there it link to your router
xyzabcxx
Recontracted from M1retailer but they told me cannot upgrade the router. Offer only for COMEX :(
200Mbps speed was upgraded this morning.
mata_hippo
dun try then how pple can help you ?
U understand the logic or not
I got Internet connection when I use my current router... a linksys e1200...
When I plug in the Asus I dun have have connection... like this still need test direct? :s22:
goldenbear1980
Wonder if any kind and experienced bros can help me troubleshoot my network.
I'm currently on M1 100mbps from 2 years ago, using white ONT, Huawei router HG256 in the living room, and ASUS USB-N53 in the bedroom.
When I use speedtest.net to see how fast my internet is, I'm getting a low download speed, around 10mbps.
What am I doing wrong, and how can I improve my internet speed?
Please feel free to ask for any additional information needed. I'll try my best to provide with my limited IT knowledge. Thanks :)
Call M1 to replace the white ONT to the black one, it is FOC. I had lots of problem and they just replaced it 2 weeks ago, after much delay which they claim due to opennet backend. Now the internet is faster and more stable.
fuzzybear
ok just check now
my ip has changed from 175
to another one
and my speed is up from 25mb to nnearly 100mb
but not 200mb as expected
odd even after i power cycle my ONT and router
tested on wired
tested on both mac and windows
going to try direct connect if got time
and use a better cable :)
cat7 ahah got afew at office to play around
