[Maylyn's Review] ASUS PCE-AC66U Dual-Band PCI-E Adapter
maylyn
Christmas came early, what a way to celebrate 2012
Introducing the world's 1st 802.11AC ASUS-PCE AC66U Dual-Band PCI-E Adapter which allows up to 450Mbps (2.4GHz)/1300Mbps (5GHz) wireless
Perhaps it's the world first review on 1st 802.11AC ASUS-PCE AC66U Dual-Band PCI-E Adapter as well, hope i can do Singapore proud on how we embrace the latest technologies =:p
Let's the pictorial kick start the review. Do note what is shown in here does not reflect the actual shipping 802.11AC ASUS PCE-AC66U Dual-Band PCI-E Adapter
Front
Back
Contents
Love the driver disc :D
Actual ASUS-PCE AC66U Dual-Band PCI-E Adapter
Back
maylyn
ASUS-PCE AC66U Dual-Band PCI-E Adapter in action
Antenna Base
All together
Antenna Base in action (it's magnetized)
Stay tuned for more
maylyn
Wish i can show you guys more, but due to some unforeseen circumstances of the wrong drivers/utilities suite that's comes with it. I'm not able to initialize it
Well, that's what i'm here to do advance review and feedback, have to wait until Wednesday to pester ASUS TW for the correct drivers/utilities
Until then and Merry Christmas
Some setup shoots
maylyn
ASUS PCE-AC66U Dual-Band PCI-E Adapter Christmas Tree :D
Mean time i'm changing my PSU ~> this :D
hsComu
I would better ask:
- when we can buy it locally
- and how much it will cost :)
ASUS@SG
Suspended
ASUS PCE-AC66 - 802.11ac Dual-band Wireless-AC1750 PCI-E Adapter
World's fastest 5G Wi-Fi
The ASUS PCE-AC66 is a new 802.11ac Wi-Fi PCI Express adapter which upgrades your desktop from tangle-some Ethernet cables to carefree industry-leading 802.11ac at up to 1.3Gbps. Plus, the stylish external magnetized antenna base gives you more flexibility in adjusting antenna placement to get the best signal reception quality possible
  • 5th generation 802.11ac chipset gives you dual-band 2.4GHz/5GHz for up to super-fast 1.30Gbps
  • Flexible extended antenna placement helps you pinpoint the best reception in your environment.
  • Instant Wi-Fi upgrade for your desktop: no more messy Ethernet cables needed.
  • High-power design clears up dead zones with 150% greater coverage
  • Custom heatsink dissipates heat for more stable and reliable non-stop operation
Fastest Wi-Fi standard: 802.11ac
The PCE-AC66 uses Broadcom’s new 5th generation Wi-Fi 802.11ac chipset to reach speeds of up to 1.3Gbps through the 5GHz band, which is three times faster than 802.11n Wi-Fi. At the same time, it maintains full backward compatibility with all previous Wi-Fi protocols, providing high performance two-way transmission while ensuring a smooth transition to 802.11ac and seamless interconnection with existing devices.
ASUS USB-AC53 - Dual-band Wireless-AC1200 USB Adapter
  • Extra-fast 5th Generation Wi-Fi at up to 867Mbps/300Mbps
  • Selectable 5GHz/2.4GHz dual bands increase signal clarity for better HD multimedia
  • Powerful 2x2 embedded patch antennas (PIFA type) improve signal range while integrating into the attractive design
  • Exclusive NetClip and cradle accessories for convenient placement and better performance
The USB-AC53 presents the first ASUS 802.11ac dual-band 2x2 antenna USB adapter with speeds up to 867Mbps/300Mbps in 5GHz/2.4GHz. Its internal patch (PIFA) antennas offer better network coverage, while the innovative ASUS NetClip helps users flexibly place the USB-AC53 to optimize signal transmission. The package includes a custom cradle for further usability extension.
Stay tuned for more information :)
danxiaogui86
is there any issues if i run this off a 8x pci-e slot instead of 4x? cause my another 4x is blocked by gfx card :(
By right it shouldnt IIRC.
laoma-ge
Need Help to Setup VPN Server on AC66U
Can anyone help me out on how to setup VPN Server on Asus AC66U Router?
I am on a Static IP with MyRepublic, I had tried to do it going into the Router VPN server page and do the initial setup but I still could not get connected from outside. Do I need to change something in the DDNS/WAN setting?
Thanks in advance
ernetlo
Hi there,
I purchased this item as well but based on my inSSIDer I am only running on 450Mbps Wireless-N only.
I am logged onto my RT-AC66U's 5Ghz SSID but I cannot get it to read as AC. I have already changed the settings on the router to become N+AC and 80mhz only.
Please advise, thanks!
ASUS@SG
Suspended
Hi there,
Please provide router 2.4Ghz and 5Ghz settings.
What do you mean by cannot read as AC?
ernetlo
Good afternoon Mr Asus,
These are my settings for both 2.4 and 5.
2.4 - Wireless Mode: N only - Channel Bandwidth: 40MHz - Control Channel - 1l - Auth Method: WPA2-Personal - WPA Encryption: AES - Network Key Rotation Interval: 3600
5 - Wireless Mode: N + AC - Channel Bandwidth: 80MHz - Control Channel - Auto - Auth Method: WPA2-Personal - WPA Encryption: AES - Network Key Rotation Interval: 3600
What I mean by cannot read as AC is that when I use inSSIDer, it shows my 5Ghz SSID as 802.11n and not "ac".
Also, when I click the bottom right hand WIFI signal indicator in Windows 7, and I highlight the 5Ghz SSID, it also states radio type as 802.11n.
honfui
Hi, I just bought the AC68 last week. Is there a upcoming PCE-AC68U releasing soon (if yes, when) or should I just get the PCE-AC66U first.
