Galaxy S4 :4.9inch smartphone
liuhao
Its good. i using this type of cheap cheap temper glass.
Those branded one also use china made one..there just repack and sell at high price.
protection and quelity is the same..
hmm...for S4, it's not same as branded one like spigen. if you look at spigen glass protector, it cuts a hole for the home button. this cheap one cuts a slot all the way to bottom for the home button.
the cheap type does cut a hole for iphone type but not for S4.
freedomczh
Hi I just bought an Arctic Blue S4 and find that the screen is more yellowish as compared to my old Nexus 4 and iphone 4s. Is it normal? thanks.
Computeron
sorry ah.. I got a cheap that cut a hole.
JAson1980
NO wor, some people believe paying $50 for some protection ish godly one :s13:
storm913
Hey guys, i came from the apple side to S4 and like to get some help with it!
1. What SD card is okay to use with it?? I see many cases of SD card being fried, Class 4/6 Samsung, 32gb can??
2. Is there any way i can watch RMVB videos on MXplayer?? My friend's Ino plus could but i couldn't.. Any idea why??
3. I need to get another charger, where can i get one with similar output but not original?? (any good deals?)
Thanks guys! There's plenty more qns but i guess i could slowly read the threads for those not as important ones!
ZhuTou!
1. Sdcard i think heng sway ba
2. Use Diceplayer, can play all format
3. Qoo?
Computeron
hahah... now ppl knows u use glass, they think u hardcore liao... just dont tell them the price... now they all thought all glass came from SGP. :s13::s13:
if i didnt tell u my cheap glass, u also think i gody too..
sorry i forgot th link liao... cuz bought very long le.
mr_voodoo
:s13: i was comparing my release set S4 to my friend's artic blue and found mine Yellow-ish.
another friend's S4 more warm then mine.
diff set diff colour temperatures, can't avoid even for iPhone
just go to display setting, change the mode to whichever you prefer.
ting
anyone had issue of the blue led permanently on even with no notification pending...just started ytdy and tried restarting and removing batt but to no avail...any advice besides a factory reset?
TIA!
derekliu
When gg overseas. To disable data roaming but still able to make international calls, its just disable the mobile data option from the dropdown menu
kl39717
Just leave the mobile data on n data roaming off will do.
liuhao
ok. just share my findings.
there are many s4 glass protector on ebay. cheap free shipping ones from HK are all 0.4mm/9h type. there are 0.3mm type (hardness reduced to 6h from 9h) from US but shipping not free. there is no 0.15mm type like Spigen nano slim found on ebay.
on dealxtreme there are 0.3mm ones for s4. cost is about US$10. free shipping to singapore.
trustME_
Guys, is it a common problem that my screen brightness will auto adjust (mostly when I'm using chrome) when I have turned off all the necessary settings relating to brightness tone adjustment?
Computeron
very obvious is low batt right??:s13::s13::s13:
pentium77
S4 wifi
hi I m a new user for S4,like to know from u guys is there any problem with the wifi ? cos mine don't seem to connect or I should say the 2 small arrow under the wifi signal bar don't really move.i check my signal is very strong.hope senior S4 user can help me out,thanks
