May 2013 Sembawang BTO
slothbal
Does anyone knows why stack 733 for 5 room is the most expensive in all projects in semb may?
Gixxerfied
Dont think it's the lift cos if that's the case then the rest like stack 731, 739 & 741 should be the same..
MBoI1986
Going for the appointment on 18 Sep 2013... Planning to select a unit at the highest floor at EastWave 4-room, level 15. I think only Blk 120C have it. Wonder if it is good or not since its in the middle both supermarket of EastWave and EastBrook
Gixxerfied
Left stack 385.. Possible noon/evening sun..
lifeisfullofupndown
Nope.my queue no is drawn under PPS scheme. So I couldn't drop out of the PPS. Similar to ur nickname, life is full of up and down. You never know!!!!! Might be a unit waiting for u!
Though your Q No. is not very good but still 100+ more than mine. I believe can still find an ideal stack with reasonable level... Just like what you have said, hopefully I can find "that" stack and the same goes for u... :)
3 more weeks to selection!
galaxy_henry
Hi Bro,
Manage to select a flat today?
3G SAINT
Around 330k inclusive of resale levy.
My parant own it. I bought resale hdb.
:s8:You mean your parent is the owner as you just help them to select since you have ur own resales flat so ur parent existing flat need to sell out rite:)
