trustME_
- Nov 12, 2011
very obvious is low batt right??![]()
nope, 80 Percents
nope, 80 Percents
are you on power saving mode?
1. Sdcard i think heng sway ba
2. Use Diceplayer, can play all format
3. Qoo?
anyone had issue of the blue led permanently on even with no notification pending...just started ytdy and tried restarting and removing batt but to no avail...any advice besides a factory reset?
TIA!
went to samsung ytdy and according to them, it was the earphone jack causing the problem! i hv nv even use it b4!
anyway they got it replaced and changed the batt as it was bloated. not bad for service i shd say.
Is it worth to get S4 now?
or wait for Galaxy S5?
my dad can re-contract anytime, since jan 2013 contract ends!![]()
nope , i off everything that is related to auto brightness adjustment .
What powerbank do you guys used to charge s4? Any recommendation? Thanks
You may want to wait for i9506 which was recently registered to be listed in IDA by Samsung Singapore
Are you using the chrome from playstore or default browser from Samsung? Samsung browser which is also based on Chrome have the setting that allow auto brightness
what the difference with i9506?
so when will it release? is it same as Galaxy S4? got any new update with the i9506?
by the way, should I still wait for Galaxy S5?![]()
Chrome from playstore![]()
Spec is almost the same except that it run on Snapdragon 800 2.3Ghz processor and support LTE-A. There is no official news on when it will be available but it had been officially registered with IDA and FCC of USA. Read this for more information.
IMHO no point waiting. By the time S5 is out, you will want to wait for S6, 7 ...............
oh I see...
then nothing change at all...
so now singtel,starhub,m1 selling S4 are i9506?
you also using S4 now?
by the way, when was Galaxy S4 release one?![]()
Anyone use Anker PowerBank to charge their S4? How is it?
