Mid range rig suggestions needed !
PDA_lover
Friends,
Newbie here. I am looking to build a rig for my personal use (mainly watching HD movies/ browsing / Photoshop etc.) These are the main things i think i am focusing on
1. Sata 6GBPS
2. Gigabit ethernet (prefer 2 but 1 is sufficient)
3. dual channel DDR3 RAM support
4. USB3 (as many ports i can get)
5. Micro ATX build (due to space constraints)
I am leaning towards i5 4570 CPU and would use the existing monitor, onboard sound and GPU. I have listed all the Mobo's i can find, please help suggest which one should i go for
ASROCK H87M Pro4
MSI H87M G43
MSI H87M E43
GIGABYTE GA-H87M-D3H
ASUS Maximus VI Gene
ASUS H87M - PRO
ASUS H87M – PLUS
ASUS H87M - E
Also suggest the RAM, Casing, PSU for the above. Also want to keep the budget as low as possible (likely in the range of 800$) Help much appreciated
PDA_lover
Bro, it seems that you have inlcuded the GPU which i think i will use the onboard one as i dont have gaming requirements.
royfrosty
For $800 you shouldn't be looking at haswell 4570. An ivy build with almost the same performance you can get the i5-3350p. Furthermore since you are doing some Photoshop things, best is to go for a nvidia range. And furthermore do you need os? Your usage isn't high. An ivy build would be a better choice and won't hinder much on graphics card.
Asrock b75m + i5-3350p ~ $271
Kingston Value Ram 8gb ~ $81
WD Blue 1tb ~ $81
Leadtek gtx650ti boost 2gb ~ $227
Coolermaster elite 361 matx chassis ~ $52
FSP hexa 500w ~ $58
Samsung ODD ~ $21(optional)
$790 buy at tradepac. DIY.
royfrosty
But you need it for Photoshop. unless your Photoshop isn't intensive at all.
PDA_lover
Yes bro, my photoshop use is not heavy and graphic intensive hence the choice to use onboard graphic card. BTW if i remove the Nvidea card i can upgrade the configuration you suggested to haswell?
royfrosty
Yes if that is the case then
MSI B85M g43 + i5 - 4570 ~ $ 356
Kingston value ram 8gb ~ $81
WD blue 1tb ~ $ 81
FSP hexa 500w ~ $ 58
Samsung odd ~ $ 21
Total $648. If photoshop isnt needed you can go even lower till an i3 or pentium can save even more.
melovelinux
seems like you do not need anything too powerful, this should be good enough
