fuzzybear
- Apr 27, 2000
do i have to wait for anything after i say ipconfig/renew?
should be bery fast
after u done those command if u want to make sure just go reboot
comp
power down and up your ONT and swtich
but usually it will auto detect one
but power down and up is just to make sure it automatic detect
btw did u try connet direct without the swtich
example ONT to computer via cable?
if works then might be soething wrong with the linksys swtich liao
as that linksys swtich is a unmanaged swtich means it will auto assign IP to u u cant do anything to it
