M1 FIBRE BROADBAND DISCUSSION / NETWORKING SETUP / INFO / PROMO
fuzzybear
what ip u r on m1 now?
175..xxx.xxx..x
124.xxx.xxx..xxx
im now on 124...
before was on 175
u try pwer down ONT and power up see if your IP on m1 wil changed
fuzzybear
what is power down ONT?
im on a 1000mbps full duplex.
ok u r good with full duplex
power down ONT is
the black ONT the huawei the one m1 given u to
means - off it then wait ahile like 1min then power up again see if it change the m1 ip to either 175 or 124
try to get a diff ip u r using now
purpledragon84
Hi guys, quick question, i just upgraded from the 100mbps to the 200 mbps plan and they delivered to me this free black router. do I swap the routers myself (from the old white huawei one to this black Asusu one) or wait for the M1 guy to come and set up everything?
momolover26
Pls ignore my previous post.
Just one question.
ONT -> wired -> N56U -> wired -> PC
Do I still need to get a wireless network adapter for my pc? Would not be using wifi on pc.
Tks.
gabbylee690
power down ONT is
ok, i off and on le. how to tell if my ip got changed?
btw, regarding the black hua wei box right, im supposed to connect my router to port 1 right? den my lan cable plug to where? the asus router or also the modem?
fuzzybear
did m1 say they. coming down to swap your old white ont to the new black ont ?
fuzzybear
did u do a speedyest before ?
from there it will show your m1 ip
then after u off & on ont then u do speedtezt again u check if ip is changed
black huawei port 1 is to your router internet port if u got a router then from router got 4 port out to your comp
if its a switch then from ont port1 u connect to any port on swtich
waiken
m1 give u router not ONT... ONT installation must make appointment n right now m1 seems to have comms issue wif nucleus connect
see many pple complain here liao
purpledragon84
yah M1 coming on Wednesday to "trigger the service". I don't know what that encompasses. That's why I don't know where they will swap it or not. Anyone has any experience with this?
fuzzybear
if this case it might be they come down swap ont or only just to test your internet only
is u want to sure try call them to verify
123qwesz
M1 just went to my brother's house to do the ONT installation. He tested using ethernet port but didn't want to pay the extra $50 to do the wireless setup with the router.
Now, he's having trouble activating the wireless using the router. Can any bros help? :(
j_t_fusion
just follow the setup guide in the cd that came with the router...
123qwesz
Ok thanks, got it working already.
For wireless, any recommendations to improve the download speed? Currently getting only 35mbps on the Zenbook Prime.
gabbylee690
hahas, ps i dont understand.. sry, i new to networking stuff..
so my black huawei, port 1 is give to the little box with the orange wires?
den if want connect lan cable to pc, is use router or connect to the huawei box? cos currently, i connect my cable to router as my home got ppl need use wifi.
fuzzybear
give us more info on your equipment and cable type
equippemmr
router
LAN cable
computer or phone but when I Google your Asus laptop it don't show it support 5ghz
I recall zenbook not sure which model seem like it not cater to the latest dual band or let alone 11ac standard
guess u pay for what u get still matter
my 2011 MacBook still can support 5ghz
guess paid a premium pays off
fuzzybear
still at work
later I home then. I link u more
mzabu25
Apparently , tp-link is working , but ethernet to my computer isn't , tried all the ports and swapped it around still doesnt work.
you mean wifi (tp-link)?
Can advise the connection, like how it is connected.
ONT -> TP-link -> Switch or ??
