M1 FIBRE BROADBAND DISCUSSION / NETWORKING SETUP / INFO / PROMO
gapboy
SGIX i max 120 only. nvr higher than tat. anyone get near 200 ?
same question been posted few time by others.
1. Wired or Wireless? What type of CAT cables are you using?
2. Router type? Gigabyte LAN and check PC Ethernet adapters if supports 1gb duplex
yoman8
Wireless, AC66u, 6200AGN.
u can get 200 on wifi ??
fuzzybear
bump too this should be SOP
fuzzybear
ah.... with Wifi N around 80-90+mbps 5ghz never more... I should think if AC this might be better in speed range
I'm on ac66 80mhz
5ghz
test on macbook pro no 11ac wifi still can reach close to my wired speed
sometime subjective
example home layout
interference
equipment wifi quality
just like wired got diff grade of cable even it cat6
zapper_hj
it mgiht be y our laptop liao
if change cable and direct ont and if after call m1 still say its upgraded
then u GG liao
anyway your cat5e cable is what brand one got from where
i dont think is my lappy ba. anyway i tried all de possible way of wired to my both com and de result is de same :(
haha i nv notice de brand ^^" anyway one is de one i using quite sometime(i wired it from living room to my room, quite long). got one is come with de ONT de and the other one was from de asus router package de.
anyway i finally get through their damn hotline and de technical side told me that my plan over his side still show my old 100mbps plan. so he transferred me to the sale dept and ask for a activation of my 200mb plan. they told me it needs 3 days to activate so let's see how it goes then. hope it goes well haha.
fuzzybear
if I test all still same and m1 say your plan atoll not boosted then is m1 fault
hope after m1 booster your speed then it on the paid speed u suppose to get
wchryan
m1 and open net come on wed. open net done checking no problem is m1 hua wei ont spoilt. now download and upload is 200mbps wired. wireless max 100mbps at my room.
undead102
Yo can share how far is your router at your living room to your room wireless adapter? 100mbps wireless is very good speed. I can only get 30-40mbps max and that is only during off peak when alot ppl sleeping like 1am to 5am time. Other time is like 8mbps to 15mbps wireless 15m distance away from router.
cscs3
After varies bang table since FEB this year. M1 finally agreed to switch my old hardware (white ONT and RG) to new black ONT using the EXACTLY the same fibre port (as open net/M1 claim there is capacity issue in my area).
The whole process is quick and clean. About 11am in morning, my broadband is stopped. Technician show up around 330pm and within 30 min. I am up with new hardware.
M1, what take you so long ! I have been suggesting using back the same fibre port and they refuse to admin this is possible!
Most important:
1. The new hardware is so much faster even I remain on the same plan.
2. I can now consider to re-new my contract instead of moving to another vendor.
mizarahi
My bil said fibre installation for exec condo needs to pay. Thought all hdb first time free. Maybe ec not consider hdb
fuzzybear
Most important:
good for u
