[Help] Choosing between Volkswagen(s)
TopGun
Is better to check the travel distance then calculate against the quantity of fuel you pump. MFD reading is not necessary accurate.
16km/l is measured via distance traveled versus quantity topped up.
TopGun
Typically, Cont car is heavier then Japanese made type. 1.4L is really under power for city drive.
The 1.4 turbo is a much better drive in city compared to the 2.0 civici used to drive.
The torque comes in at 1500rpm. Gear shift at 2000rpm. The civic has nothing below 2000rpm.
cscs3
Has drive both, but is a opposite experience compare to yours.
jittery
zua to 3000rpm the vtec kicks in is jin song..
