Corsair H60 Liquid CPU Cooler fit LGA 1150?
windwaver
I am currently using the H60 for my LGA 1155, just like to know it supports the new LGA 1150 socket too?
Thanks.
royfrosty
Thanks.
Yes no doubt about it it can be used. Cause it uses the same back bracket for the 1150.
1oriYagami
Thanks.
How is the cooling capability of the H60? H100 seems to have plenty of gd review, but a bit costly
royfrosty
H60 is just an entry level AIO cooler. This one not very good. Its about the same as a Heatsink like Xigmatek Gaia etc.
H100 is a top range. It is way bigger. 240mm radiator.
Outside you can see many good reviews. But our dear forumers here have already made a lot of bad reviews with the H100.
Some already complain it shorted some 120mm fans attached to it and in the end the cooler just wont work.
Some mention corroded pipe ends.
Do a quick search then you will understand what they mean.
If possible can go for CM 120M seidon or NZXT Kraken.
bhtan83
Bad quality... so far swift tech H220 and Thermaltake water 3.0 extreme are the best.
royfrosty
Ahh forgot about the thermaltake water 3.0. This cooler is also one of the best range out there. Nice design also.
windwaver
Which CPU are you thinking of cooling?
H60 is the entry level but so far it has been working well for me in keep in temps down. The fins are easy to clean and very easy to install.
HKSboy
Comes w/ Blink blink? :s13:
Either the 3570K or 4670K.. still comtemplating :s22:
old h60 and h100 have better materials used if I may say than the new h60 and h100i..
search here the issue of their tubing on the h100i if that does not bother you the performance of h100i is ok
edit found it:
http://forums.hardwarezone.com.sg/c...-scratched-h100i-tubes-corrosion-4353048.html
That's horrible !! Was thinkin if the cheaper CM Seidon V will do the trick?
royfrosty
No lah. Like the black and white theme.
HKSboy
shadow84
Meaning the Thermaltake words does nt glows when powered?
The Kraken X40 review looks good. Any idea where can get in SLS? Hope the price is attractive :o The TD02 seems to be out of my budget =x
If u r going for 120/140mm rad, get the TD03.... TD02 is 240mm
