You can delete apps from your list. Go to All under your app list and remove from there. Touch the "x" to remove single app or touch and hold to remove multiple apps.
Oh cool, didn't realise it could multi-delete. Hated deleting them 1 by 1
really ah bro..
me scare what if the product is fake from online purchase how...? aiyo, already bot liao, just enjoy the full HD movie from torrent, each movie around 1.7-2gb one64gb very fast full leh...hope it can support 128 GB
Hi, can you guys help?
Been encountering the above error for the past 2 hours.![]()
Anyone...?![]()
are people having unrealistic expectation of this phone? I see so many complains in this thread.
Can you screenshot the entire phone screenshot? How did you end up getting this? Got reboot phone try?
You have microSD card? If have, removed it and reboot phone. See if it's still present.
Not too sure about getting the more expensive ones cos UHS-I support is not present in Note 3 so it most likely won't hit that speed. But if the price is more or less the same, just go for it![]()
I am also considering to get this, where you intend to get and what the price? I found currently shop cheapest is $118. But for this price... can get 2 pieces of 64GB Ultra... so need to confirm can use on our Note 3 or not before buying...![]()
Anyone...?![]()
i bot samsung MicroSDXC for my note 8, should be able to use for note 3 ah...
Read : up to 70MB/s with UHS-1 interface
Write : up to 20MB/s with UHS-1 interface
challenger member only SGD99 vs samsung store SGD135, real performance?? really fast(as compared to my sandisk ultra 64G which i bot ~SGD80+)
Is the Yahoo Finance widget..? Or the bloom berg? If not, try rebooting phone? Or clear RAM?
I'm now in SL SQ pondering whether to buy that SanDisk 64GB microsdxc uhs-1 class 10 for $118
I use neither.
Tried rebooting and clearing RAM too. Still the same.![]()
Samsung confirmed that the Note 3 supports their Samsung 64GB microsdxc UHS-1 Class 10 card with no issue on speed and capacity
Other brands not sure
One question. Is there any Android software that can test the card's write/read speed? Windows has one but not sure of Android.
So far I found the following pricing at a shop...
SanDisk 64GB Ultra (30/??): $60
SanDisk 64GB Extreme (80/50): $118
Samsung 64GB PRO(75/20): $99
Hummmmm....![]()
for note 3 buy samseng lor, any problem they cant blame you that your sd card got compatible issuemy own logic haha
I use neither.
Indexing service probably means the file system indexing. You might have gotten a lemon, just send in for servicing.
