Really happy user at the moment that I could get what as promised.
Direct LAN.Direct LAN or wireless?
Thanks bro.Congrats bro! Enjoy your new speed![]()
we consumers are easily satisfied...we get what we pay for...why some telcos cannot get it.
Direct LAN.
Thanks bro.
True. I hope my speed maintains for this 2 years. Else will have to jump ship again. Now also using starhub broadband.
Some telco is pay more but expect less![]()
White ONT is the same one as the Starhub and MyRepublic are using because there is a Nucleus Connect (NC) wording.
NC is the first Op-Co in the NGNBN who is a Starhub subsidiary and all ISP buys bandwidth from NC, including M1. (Did Singtel offer Fiber back then?)
However, eventually Singtel, ViewQwest and M1 also got their Op-Co license and hence M1 is not going to buy the bandwidth from NC anymore which is why they are pushing people to use their own black ONT.
To end user, White and Black ONT does not differ as both are capable for 1Gbps speed. However, as M1 is not going to buy more 1Gbps line from NC, they are going to "cap" the White ONT for the users of now defunct 100Mbps plan and charges some rental fee so as to encourage user to use the black one instead.
But then for those who are upgrading from 100Mbps or whatever to new 200Mbps, it is causing some trouble as Port 2 of the TP needs to be activated (And now it is not provisioned during the first day to install TP. Not sure if Port 2 is provisioned at the beginning or not.) and somehow is causing reports of unpleasant experience with delays etc for some.
You are new signup, m1 will give you black. They no longer issue the white ONT. Black has built in phoneline port. Installation should be a breeze for new signups. Setup for asus n56u also easy. Plug everything in place and follow the simple steps on the guide and you are gd to go. Just make sure you dun mess with the yellow fibre optic cable, dun bend it too much.Hey guys i have the M1 coming on next friday to set up the ONT. may i know what is with the black and white one? which one would they give me and which is better? both are compatible with the N56U asus router????
Hi guys
Just want to check with you, Opennet has just installed my TP point earlier on and signal tested was -15db.
M1 is coming down with the ONT appointment on Friday.
If everything goes smoothly, when will I be able to start using the fibre?
Hi guys
Yesh.... Dun make tea, he'll be gone in 5mins.Thanks! They'll be here just to test the signal strength again and plug in the ONT right?
opennet came down to activate my port 2 on 14th oct. which means it's activated lioa ?
do u mean that i can use my current white ONT with 2nd port activated now ?
What cable you using? 0 lantency..![]()
