[Software Update] iOS 7.0.3
*adiBOY
Available from iTunes or OTA!
Full changelog:
- Adds iCloud Keychain to keep track of your account names, passwords, and credit card numbers across all your approved devices
- Adds Password Generator so Safari can suggest unique, hard-to-guess passwords for your online accounts
- Updates lock screen to delay display of "slide to unlock" when Touch ID is in use
- Adds back the ability to search the web and Wikipedia from Spotlight search
- Fixes an issue where iMessage failed to send for some users
- Fixes a bug that could prevent iMessage from activating
- Improves system stability when using iWork apps
- Fixes an accelerometer calibration issue
- Addresses an issue that could cause Siri and VoiceOver to use a lower quality voice
- Fixes a bug that could allow someone to bypass the Lock screen passcode
- Enhances the Reduce Motion setting to minimize both motion and animation
- Fixes an issue that could cause VoiceOver input to be too sensitive
- Updates the Bold Text setting to also change dial pad text
- Fixes an issue that could cause supervised devices to become un-supervised when updating software
ralliart12
Can try to observe if the gyroscope/level issue is rectified in the patch.
bryant_16
Found a bug. Let say you are in safari browsing webpage. You pull down the notification centre and pull up afterwards, your current safari page will be scrolled all the way to the top.
You try pulling down and up a few times, and you will know what I meant.
Not just in Safari, any other applications as well.
layzibum22
Not the case for me for Safari... It's working fine.
deep3lue
I don't have your bug on my iPhone 5s. :s11:
layzibum22
That is because you turned on Reduce Motion in the Accessibility section mah. :s13:
Was getting used to it... And now feels weird don't have the apps drop down effect..
But of course the new style transition feels faster...
deep3lue
Some other notable changes are the lock screen notifications have changed a bit.
Now there are lines separating the multiple alerts.
