Newly.
- May 10, 2009
Clear Cache and data then Uninstall the 4.2.2 updates for Google+. Then go to Google Play, my apps and update Google + to 4.2.2. Should solve your problem.
Thanks. It works !
I try google for the answer but search result did not came out with any solution.
Am very glad I am able to get the remedy here.
Glad that it is working. I faced the same problem and this method solved it.
