Aztech DSL7000GRV router from Singtel
ideatalk
Did you key in like this.
User Name: admin
Password: H3ll0t3ch
not
User Name: admin:H3ll0t3ch
Password: admin:H3ll0t3ch
:s11:
thanks bro, manage to get in.
i plugged my thumbdrive into the router but cant see my thumbdrive from my window explorer. pls advise how to access the thumbdrive
ideatalk
thanks. finally got it right. just clicking on the network and sharing then comes the BRCM Samba
joschia
Can I use Aztech DSL7000 with M1 Fibre.
What are the settings I need to change in DSL7000 in order for the internet to works?
Thanks
XsenseX
Anyone knows how to access the samba server in Mac?
I've activated the 'guest' option already.
Tried connecting network 192.168.2.154 but doesn't work ...
joschia
Thanks
Anyone can help?
The internet don't works when I connect the m1 not to aztech dsl7000grv...
Thanks
ideatalk
heard that M1 users have to deal directly with Asus if their router got problem which is diff from Singtel which we deal with them directly. (one stop shop)
So for M1 customers they have to deal separate issues with diff ppl, internet problem call M1, router problem call Asus and ONT problem call who?
Although the monthly fee is cheap but the overall time needed to resolve problem is damn time consuming and expensive when u have to apply many leaves to talk to so many parties.
renfred89
ONT call M1 also.
The reason why Singtel provides technical support to their routers is because these are residential gateways customised for singtel.
M1 merely engage a 3rd party brand for router provision only. Of cos u go back to avertek for servicing.
ideatalk
just received my dual band wireless card will setup and test....hopefully theres speed improvement
sigh
User Name: admin
Password: H3ll0t3ch
Anyone know if there is a different password? I tied the above still cannot work. I know it is case sensitive and ti is a 0 and not an O
sigh
Found out what is wrong. 192.168.1.254/singtel
I didn't put the /singtel
xxixii
Can anyone please advise whether/how I can limit the speed of selected connected devices via their MAC address? Thanks :)
Shem2202
Port Forwarding Set up for Aztech DSL7002GRV(S) and Synology DS1812+
I run DDNS on my NAS (synology) which seems to be able to pick up the public IP and update it regularly. I can test this by going to xyz.synology.me. However, I am presented with Aztech configuration page. I tried port forward in Aztech config so that 80 is forwarded to synology (including other services such as web service on 5000 and 5001 etc too). None of these work. The default port 80 continues to take me to Aztech page. Other forwarded ports e.g. xyz.synology.me:5000, refuse connections. I even tried this with external IP (that shows up DDNS update). Same issue. Has anyone successfully managed to port forward on this model?[/QUOTE
I need to perform the same set up with my new DSL7002GRV(S) and Synology DS1812+. Has anyone managed to set this up & able to provide guidance in the steps? Thanks.
