ralliart12
- Jan 11, 2003
Btw, anybody has any quality 3rd-party Smart Cover (not case) to recommend? The one I bought costs ~SGD$7, but the quality is also literally around $7, ha! Specifically, what I dislike is:
1) the dimensions of mine is imprecise, i.e. larger than the mini. When the cover is closed, there's a margin of excess when the entire unit is viewed from the rear. I'd bought an original Smart Cover for a full-sized iPad before: IIRC, the actual dimensions of the cover is in fact, just a tiny bit smaller than the device so that the cover's edges are guaranteed not to extend beyond the perimeter of the device.
2) the inner surface of mine doesn't have the nice micro-fibre finish of the original.
3) the seams of mine is much stiffer than the original. This translates into the fact that it doesn't fold into a triangular support as readily as the original, & it also tends to spring back into its flat configuration extremely easily (this isn't a good thing, for me at least). When I was using the original (for full-sized iPad), I can feel that the "seams" dividing the flaps are intentionally weakened to make the entire cover change folding configuration properly.
So, if anybody has used any decently-made 3rd-party covers that doesn't have the faults I mentioned above, I will like your recommendations. Otherwise I'll probably shell out the full $38 for the original one eventually.
Holy Crap: I just realized the original one is $58, & not $38.
