avviicc
- Nov 15, 2011
ok. seems like 2013-2014 is over..
For those applying for 2014-2015, especially Poly students, here are points to note from my own experience.
1) O level plays an IMPORTANT part in application for NUS and NTU. If you have a lousy O level, is better to apply for easier to get in courses like science etc...
courses like Business, accountancy is out even if u have GPA over 3.8 if ur O level is lousy...
How ur know ur O level is lousy?? compare ur O level with ur peers in poly. If ur O level is like among the lowest , then is lousy
2) Ur order of your choices is very important. Even they say that the order of ur choices is not important, trust me, IS IMPORTANT!!!. If you not confident of ur grade, apply a easy to get in course as ur 1st choice.
Eg: ur gpa is 3.7, better put a course with lower 10th percentile of 3.5x.
3) SMU is slightly easier , but u have to excel in the interview and written test.
