Digital TV (DVB T2) in Singapore [consolidated]
harky
but i asked the supplier of a portable hdd recorder le.
he say RCA only can record non-hd.
I see the box set can record up to 1080p what make me abit confuse le
HDMI or RCA is for the connection between STB to tv, it has nothing to do with the recording itself. What you need is just turn on the STB, plug in external drive and record it. You not even need to turn on your tv.
The_Davis
High Honorary Member
Deluxe Member
btw samsung F7500 can record digital channels without additional devices :)
(need external hdd)
Coolsun9
FTA channels thru DVB-C connection
are there any DVB-C set top box available?
Hello,
I am not sure this is the right place to ask, but does anyone know where to get legitimate DVB-C STB to receive FTA channels from SCV wall outlet?
I have problem getting FTA channels over the air using AC Ryan Playon DVR-HD which is a DVB-T box and a simple 5dBi indoor antenna. I suspect my location in Tampines Central at level 6 in the middle of a heavy built up HDB blocks is preventing any decent reception.
I ponder whether it is a good idea to spend on a better indoor antenna like Daiyo antenna EU1702 or a Margon Antenna. Any suggestion welcome. Thanks.
harky
sign plan with SH u got the set liao.
But than u cant borrow from other and bring the set to ur house and try becos it was tag to the address.. SH ppl will know one. (I heard this story from somewhere, u cant borrow)
btw can ur AC Ryan Playon DVR-HD record HD?
Hello,
pohw0008
If the matv has the T2 signal, the starting point is that Draco stb can decode to both hdmi and composite output.
If you want to use the draco output to connect to all 3 tv at the same time, I believe the draco is unable to supply the signal. Even if it can, the distance involved will make it a must to get quality hmdi cables plus hdmi splitter. Estimate the cable length involved and work out the cost.
ok, seem too troublesome for me to do all the cabling.. shall stick with sd tv for now.
thanks for the info :D
Coolsun9
I am trying to get HD5 channel from the DVB-T box to record HD. But the box uses AV cable for recording. Not sure I can record, when the TV normally does not have an AV out.
harky
the RCA cable only can record max 576p (DVD format)
cannot use hdmi?
harky
by right not reverse.
i also tot of hooting this set na.. but i asked the supplier it say cannot record HD becos it use RCA. But i see the box set say support 1080.. tht one is for playing only ah :(
I see. The DVR has HDMI out to the TV. So, receive HD on TV but not reverse, right? eg record HD to DVR via RCA.
Coolsun9
Thanks. No point to get a UHF antenna for the DVR since it would not record HD.
btw Happy New Year to all, cheers.
SilveR1_09
Hello,
If your usage is only to obtain FTA channels from the SCV wall outlet, there isn't a case of legitimate/illegitimate I guess. Since it's FTA to start with.
There are many DVB-C boxes selling online.
I have the same set I believe. AC Ryan PVR76120 right the exact model?
The simple indoor antenna CMI. I can't receive anything too with that indoor antenna.
If I connect the set to my HDB MATV point, I can receive all 4 DVB-T programming on UHF38.
Try the HDB MATV wall point 1st if your unit still have it.
harky
can ur AC Ryan PVR76120 record hd?
SilveR1_09
Record HD off another source?
Or direct from the DVB-T tuner?
If record HD from another source, surely no. Coz the AV-IN has only composite (RCA).
If direct from the DVB-T tuner, I believe can. But I have never tried it.
Although at this point in time, there's only HD5 available as a HD channel thru it to try. Since it's DVB-T only.
PoloBoiBoi
After many queries by peeps i built HTPCs for, an update by Hauppague Singapore on the locally available Nanostick-T2. Summary/takeaway : await updated version that is v 1.3.1 and compatible with local channels (scheduled to be out Jan 2014)^^
JAN 2014 le ... HOWHOWHOW??? :(
tatsit
another, this one has MHEG5
HD DVB T2 receiver with DVB T DVB T2 MPEG 2 MPEG 4 H.264 with USB/HDMI 1080P for RUSSIA/Europe/THAILAND-in Set-top Boxes from Consumer Electronics on Aliexpress.com
batuchka
Last correspondence dated 30 Dec 13: an updated Nanostick DVB-T2 and a new hybrid DVB-T/T2/C USB Tuner ("292e" nanostick) currently undergoing testing phase in Germany =:p I have requested an update from Hauppauge so will share with forums if available locally
mrsun18
i only know it's an "adaptor" lol
not F female to IEC male adaptor
There are hundreds of adaptors. With "F", "IEC", "Male", "Female", you already have 16 different types, throw in a "Right Angle", you have another 16.
There are also BNC connectors again with many variations. I am sure the easily remembered "male' and "female" will go a long way in helping to identify the right adaptor:s22:
mrsun18
SilveR1_09
Hi SilveR1_09, not sure if you have seen this, no signal from my condo matv:
Hi mrsun18,
Yup. I've caught that. I'm in touch with him on PM.
He's using a DIY fractal antenna. Place near his window, facing South.
I tried tuning to Ch 48 off my unit's MATV using my T2 STB and also with a LG TV (DVB-T). Zero.
[The TVRI signals on UHF48 are DVB-T by the way. A bro from East Coast using a Humax was able to get them. I'm sure you remember though :) ]
No signal from your condo MATV?
Maybe it's too weak. As jywl12 noted, signal is weak even in Pasir Ris. In Bishan, perhaps off the cliff already?
