NOKIA LUMIA 1020
E_T
New Nokia Cam is really fast! Shot-to-shot is less than 3 sec, close to 2sec, even with 5mpx + DNG!
To view the DNG files, you need to download the Adobe DNG codec.
Quality is real good but each file is 41MB!
SGRevolution
anyone got a mysteriously large memory space being taken by "others"? mine is 3.36gb when i see using storage check...
E_T
Others files are fine as long as your temporary files are small. Check the system -> Phone Storage instead of Nokia's Storage Check.
kopi22
There is a new update for Nokia Camera for DNG support after Black update.
ahtea
Actually, somehow I feel Nokia is trying to make it works and look like other OSes out there. On Android (not sure about iOS), we have folders containing app shortcuts too. So, to open an app within a folder, we need to open the folder first then the app. If the user needs to have lots of apps visible within the limit screen area, it is a good idea. Otherwise, just use what we are having currently without folders.
TBH, I have been hoping to see folders for group tiles since Amber. Perhaps it suits my style as I'm also using Android tablets. But can we name the folders like on Android though? I have not update to Black yet also.
The new App Folder app should help you a little.
I just reorganized my Home screen too. Now it looks neater with the less frequently used apps which still require quick access from me, dumped into the folder.
My screen now looks neater. But a tad less colourful though.
kekacofmmhkfoll
Suspended
anyone can share the battery life of 1020?
here's mine with moderate use over the past few weeks
draco76x
After "Lumia Black" update, battery seems better, when in Amber, my L1020 can't last over a day.
With the Black update, it goes beyond a day before dies off, but I have to observe few days to confirm it.
