shokbakgoc
- Apr 2, 2008
How fast you can install win 7 depend on:
1. is the install disc/thumb drive integrated with updates all the way to current month?
2. your PC speed/memory
3. your broadband speed
In my case, windows update with OS and Office take less than an hour with modern hardware. Ever done a netbook which took 5-6 hours due to item 2 mentioned above.
Not sure whether my system configuration is too old but it's ok for my needs. It's Pentium E5700 Dual Core with 4GB RAM. I also thought the installation/update will be quite fast and I can do in the morning then afternoon go out. In the end I was babysitting my computer from morning until night just for windows installation/update.
That's the problem. Try installing 7.1 straight. way less updates
Very old system? Is the installation disc without SP1?
The installation disc came with SP1 and yet over 200 updates to download & install!!
they came in several batches - 1st prompt about 140 updates, 2nd prompt about 40 updates, 3rd prompt another 20 or so and continue to prompt for some more ... I thought it would never finish detecting and updating and restarting.
