Digital TV (DVB T2) in Singapore [consolidated]
Henry Ng
Like that might as well buy a China made HD box now. From what I know, Starhub HD box cost about $2+ per month additional compared to the old non HD box.
For Starhub TV, we have to use original HD set top box at $6/mth. It is illegal to sell/ use China made set top box to receive the Starhub pay TV channels. In 2013 a set top box seller was jailed for selling illegal set top box. Copy right act ...
somewhat
It is not true. Using DVB-C tuner to watch FTA channels does not break the law. Don't mix up with those illegal box. They were used to watch paid channels.
mrsun18
Which of these combination will work?
antenna -> dvb-t2 tv
MATV point -> dvb-t2 tv
MATV point -> set top box -> antenna (needed?) -> dvb-t tv.
Some matv points work and some don't. For explanation, please read my post #227 in this thread.
SCV point -> set top box -> antenna (needed?) -> dvb-t tv
SCV point -> set top box -> antenna (needed?) -> dvb-t2 tv
SCV point -> receiver(??) -> dvb-t2 tv
This question has been addressed.
I intend to get LG 42LN570T (dvb-t2)
But if the setup is as cumbersome as a dvb-t tv, was wondering if getting a 42LN5100 (dvb-t) and use the saving to get a receiver/settop box make sense?
Greatly appreciate some advice.
The cost of a local stb (Draco) is $119 ~ $129. The cost of 'compatible' set if you buy from overseas may cost $40 ~ $60 with no assured result. If you buy dvb-t tv plus a stb box, you will need two separate antenna inputs. You have an extra box on your tv console and have two remote controls - one for tv and one for stb. Work out your sum accordingly.
windwaver
You will be able to receive the signals these ways:
Antenna -> dvb-t2 tv
MATV point -> dvb-t2 set top box -> any tv
Miotv set top box -> any tv (soon)
SCV point -> Starhub cabletv set top box -> any tv (soon)
On the SCV portion, it's
SCV point -> Starhub cabletv HD set top box -> any tv (soon) because the normal non HD box which many people are using cannot receive HD signals :).
windwaver
Not that kind of box. It's more like if you have more than 1 TV at home not connected to the Starhub box and you just want FTA HD channels.
windwaver
lowhm
Thanks for the info.
Can advise on how the receiver posted in the post above sits in the connection link?
I'm looking for something like
wall point (most likely scv-point) -> a device -> dvb-t2 tv
Initially, my thinking is, for any dvb-t2 tv, should be ideal case like
MATV -> dvb-t2 tv
So, I don't have to spend extra, but I think I'm just being naive about it.
The device would preferably be just a dumb signal converter and do not need any control like channel switching such that I have to meddle with the device remote and tv remote.
Is there such a thing?
I have read the signal strength from antenna is kind of unpredictable, thus, I'm a little hesitant on OTA signal with my area having to hang the wire all over the place to get a acceptable fm radio signal.
Or, maybe my perception is outdated.
Would greatly appreciate what are the possible approach to setup a reliable reception.
Added:
Thanks guys, quite a few replies while I'm typing this out.
Digesting them now ....
ezowulf
corrected the error. thanks for pointing that out.
hwsinn
Cani just ask...now stathub is alrdy broadcasting in dvb-c le right...the signals that come through the starhub point
lowhm
Sorry, can I know why do I need two separate antenna inputs?
I thought it will be
wall point -> stb -> tv input
Is this right?
Another question is how reliable are those indoor antenna.
I read and it's mentioned that it really depends on location.
chakuman
Just a heads up.
I saw 3 empty channels created on StarHub STB (Channel 116, 154 and 156 respectively). There is no HD logo but the audio description were displayed as Malay, Chinese and Tamil respectively. Mmm I wonder what is it...
FYI. Previously Channel 116 was 8-on-demand from MediaCorp, which just ceased transmission recently.
tuckloong
Just a heads up.
starhub given grants to produce free to air prog :)
chakuman
Guys.
I can confirm that StarHub TV channel 154 is Channel 8 HD.
Just switched to the channel, toggled the audio, and it is the same output as Channel 8 SD. And there is also a subtitle option.
Kiwi8
Deluxe Member
Guys.
Indeed... hopefully it can be unencrypted and receivable by DVB-C tuners soon. :o
