Rpm gauge moves up/down while in park/neutral mode
funky05
Just wanna check, my car rpm is default starts at 1 instead of 0 needle when I start the engine.. Last night I realized when I put the gear to neutral, the rpm moves up from 1 to 1.3 and moves down back to 1 and continues doing so for about 6 mins without me pressing on the accelerator.. Is there anything wrong? This is my first time encountering this.. Ride is wira 1.3M
RuOnline
Maybe throttle body dirty that cases the unstable revving. Can go ws have a check.
funky05
Thanks for the replies.. Based on ur experience, Issit a major issue which requires urgent attention?
ZhuTou!
its good to solve it earlier
if not car may died off while idling
quite troublesome coz u need to start engine again
k3vvie
Air con on or off? Might be the air con compressor kicks in. Den thr rpm goes lower n the ecu revs up the engine so that it won't stall?
pew
If its the throttle body, make sure the mechanic take out the throttle body and clean. Not spray the throttle body.
meganut
another possbility could be your idiling sensor dirty or a broken wire in sensor...
St00ky
my dad's car RPM gauge also keep moving up and down and there is also some vibration whenever i step on the brakes. no issues when putting the gear in neutral and park. is there a problem with the idle air control valve?
pro326
Does this happen when the engine is cold? See below
1) In the morning
2) after your car is parked for a few hours
Confirmation:
When you drive, your car will die. After a few times your engine check lights comes on??
If the erratic idling cease after the car is warmed up, then there can be a possibility that your throttle body sensor is faulty.
This just happened to me. The repair depends on your car.
Marbok_Tan
Just want to check whether it is normal for a Merc B class to experience shaking when idling? while stopping at a traffic light i notice sometimes the RPM needle will dip slightly followed by rough shaking. I didn't get any check engine light or any error messages. Just wondering if it's normal. My family's previous cars dun have this kind of problem
Geylang Prawn Seller
Yeah it's normal. Engine mounts tend to crack at the 7 year mark. But despite new engine mounts these cars tend to vibrate. Don't worry about the rpm it's just the cvt doing it's stuff
