andr3wyong
- Mar 5, 2012
Failed to add firewall DMZ port forward rule, ret = 9902
on my Zhone.
Please help
Hmm might need to reset. It's a very rare bug.
Alternative you can email NOC to try another firmware (just tell them andr3wyong sent you and they should know which version to try)
Download 311 and upload 67. Must say the upload is a bit slower than normal. Usually will exceed 100. Am on 300Mbps plan, not received the free upgrade to 500 yet.Internet have been slow for me until the point of some webpage not loading and i have to keep refreshing in order to load it ( google / facebook / gmail )
using the speed test on viewqwest , i was able to download at 200mbps but upon trying to upload it will not be successful showing Upload Test Error Download test returned an error while trying to read the upload file
Have tried rebooting my router but result stills remind the same
Anyone facing this problem as well ?
Do let NOC know. They should be able to help you re-provision the speed.
By the way do you notice any ALARM light when the slow speed occurs?
any 64bit OS utorrent user around, i want check isit stable enough as i going to build a new pc but with 16gb ram,
is the 32bit utorrent more stable than the 64bit atm? (crash issues?)
using 64 bit OS and utorrent with 16GB ram
using old version of utorrent v2.2.1 build 25130 .
