MSI GTX 780 Lighting
osiris77
Hi All,
Anyone know which store in SLS got stock or this GPU and what is price?
Thanks in advance.
osiris77
why dont u go SLS check out
I don't want to make a waste trip there and found out every shop is out of stock... Price wise should be 700+ I think but just wanna know the price to avoid getting chop...
Thanks.
AnTiLooP
just call up the usual shops and enquire with them.
pc themes
fuwell
best buy
cybermind
tradepac
need the contact numbers just google for it.
and_who
I think distro mentioned not bringing in. Go to twin frozr club search thread using keywords "lightning"
Was also looking for this or the evga classy, ended up getting the evga super clock 780
osiris77
Will call the usual shop to check then...
Beside MSI gtx780 lighting, any other gtx780 I can consider if no stock for lighting. Will not consider AMD as I will prefer Nvidia.
Looking for one with good OC capability and support for water block for WC in future. Understand a lot of non reference card do not have water block available.
pa9797
Thanks.
The last time I seen 3 in SLS. That was 2 months back. I always wanted to Tri SLI but drop the idea. I don't think the price drop to 700+ since it is the old price batch. If you are comparing with online price my advice is for you to buy online. You will never get close to those price. As for stock availability , it will not be a wasted trip to SLS. Sometimes you will see stock prop up in some shop if you manage to find hard enough.....
and_who
I have a evga superclocked - uses ref board and wty by convergent - I think PC themes selling for 789. Avoid asus cos it's non ref. the Palit superjetstream also non ref. gigabyte windforce 780 also non ref I think. Best is go to shops ask for ref cooler models- think Leadtek shld be ref board
