Ram 8gb but only 2.21gb usable. How to activate all?
caleb.seah
Hi!
I've 8gb ram installed onto windows 7 32bit. but only 2.21gb is usable. how can i activate the remainder?
Am using amd a10-6790k with asus a85xm-a
royfrosty
Hi!
No. You will not be able to use 8gb. Its they physical limitations of your OS which is only 32bit. Best is 64bit OS to utilize all 8gb.
jtjt00
A waste to install more than 4GB memory in a 32bit system.
caleb.seah
Alright! Understand! I'm currently donwloading the 64bit to re-install everything again...
Din know about it.
Is it the same for others like winds 8 and etc?
kurtisnet
Din know about it.
Yup it's the architectural limitation of 32 bit OS.
caleb.seah
Hi!
I was folowing this guide to installing windows 7 64bit as i do not have the CD, but when i click on the setup on the file, it came out this error.
Anyway i can re-install it?
shadow84
One does not simply install a 64-bit OS into an existing 32-bit OS...
jtjt00
TS, you need to clean format and install afresh either using a DVD or thumb drive.
zenniz
Oh no... You need to do a clean install for a 32bit OS to a 64bit OS.
Hailgod
Hi!
Just a question. How are u going to activate the product key of your 64 bit windows 7? i dont 32 bit and 64 bit uses the same ones right?
muddle
Rocket3, you are basically telling him to create a ramdisk out of the unusable memory. I believe ts want to utilize the full 8gb ram in 32bit os. Which is not possible unless you use the PAE switch.
Hailgod
It is POSSIBLE to use more than 4 GB RAM in 32-bit Win 7.
Download a program called 'Gavotte Ramdisk'. I'm now using it with 32-bit Win XP and none of my RAM is wasted by 32-bit memory address limitations. :)
This guide may be helpful to you: How to use full 4GB RAM in Windows 7 32 Bit (Gavotte RAMDisk in Windows 7) | Homepage of Jens Scheffler
That is irrelevant. Your computer isn't using ram as it should be, more like using it as a very fast solid state drive.
Rogue
how can i do a clean format of the computer?
Sorry total noob at computer.
Burn installation files into a DVD/CD and boot up with that and it will prompt installation.
I recommend you download Win 7 64 bit iso file and burn that instead since you seems to have downloaded win7 unpacked files.
You can use this Microsoft Store - Windows 7 USB/DVD download tool
Remember your Win 7 product key.
Ark Law
Using RAM as ramdisk =/= Using RAM as RAM
Assault
