subprimelive
- Jun 4, 2010
should be free for a long while to encourage more people useit will be free forever ?
why UOB has this "PURPOSE" field when u select FAST?
what shoould be used?
Strange, tried to transfer from POSB Savings to my SC eSaver account and got rejected.
wat is the rejection reason?
FAST is so far so good to me...![]()
I put purpose as others, maybe that's why. Rejection reason says to call the hotline...
don't think so. I also put others. it went through tho.....
u wanna cross check the account number or try again?
One thing different on FAST is, you no longer need the branch code. Hence, the account number for OCBC bank and HSBC wil need to key in full acc #
It appears this service won't remain free. On Citibank, it says:
Transfer Via FAST (Free*)
*Free until 30 June 2014
There are also issues with the transfer. I moved $5 from A, and received two deposits of $5 at B. I've already called the bank to inform them to look into the issue.
It didn't 'double' a second transfer (different amount) I did between the same banks, so it seems the problem, if any, is intermittent.
