The Xiaomi Mi3 thread
ah_bo0
Does the android beam work for the gallery?
Wanted to transfer PIC from Mi3 to HTC One, both android beam turned on, open up a picture and tap the HTC One but nothing happen....
I rem using andriod beam on nexus 4 and its quite straightforward
doki81
i didint touch any settings... i still see the singtel apn in the hp but can only detect singtel / m1 / starhub 2g
i think u better try check if you have turn off any 3g mode in the setting.
my mi3....status say shipping but no ups tracking..anyone having the same issue?
jedi5diah
use this app (wifi direct): Shareit
works with miui transfer app
Twiddlebug
same for me, shipping, ups nothing, maybe ups side haven update?
extr3mus
hey guys, just wan to check whether if your mi3, the display age and gender feature in the camera can work? i dont seems to get it to work.
TUV2008
yes, mine is working. no setting is required. it works out of the box.
TUV2008
anyone ever try to transfer calendar and note from iphone to Mi3?.... i cannot seem to find a way to do it.
beyonder
Help: I'm using iPhone 3GS for the past 3.5 years so Mi3 is my 1st Android, any1 can share how to transfer my contact from Iphone 3GS to Mi3?
What I did was I go to iCloud and export all the contacts.
Then import the contacts into my Gmail contact.
Once you sign into your Google account in the Mi3, all your contacts from your Gmail will appear.
beyonder
bros ..
need help here
my mi3 is not able to detect 3g recently ... dunno wat went wrong
tried searching for mobile network but only 2g network found
Did you check your settings to ensure it is on preferred 3G?
McdohLOR
Just to check, does it comes with dual sim slot?
Dual SIM Card Dual Standby(one micro-sim card) << what does this means?
How's the connectivity with our local telcos?
jedi5diah
No dual sim...only redmi has it...
Connection is superb with ST 3g
jedi5diah
If you save to icloud then it's not possible
Import to gmail then you are able to transfer to any other platform
